I am trying to figure out the architecture of the main wxGUI in G7. My aim is to add “Network Modeling” in the Layer Manager menubar, under Layer Manager → Raster → Hydrologic Modeling. I looked into [0], but clicking “GUI” and “Interfaces” gives me “404 Not Found” error. So, I am trying to figure out the architecture by tracking back the variable names, and discovered that I probably should add the string “Network Modeling” in the file file gui/wxpython/menustring.py but I still don’t have clear where I should add the third level menu, the event and the binding function … I feel a bit lost.
Also, I don’t understand where is located the wxGUI for each command. I mean, for example typing r.watershed in the terminal raises the GUI… where is it written? I am sorry if I ask probably silly questions, but could anyone kindly address me where I can learn more about that? So far I have scripted just for grass 6.5 and it is fairly different to programming on G7, so any hints are very welcome.
Thanks
Eng. Margherita Di Leo
Ph.D. Candidate
Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata
Campus Macchia Romana
85100 - Potenza
2011/6/23 Margherita Di Leo <dileomargherita@gmail.com>:
is to add "Network Modeling" in the Layer Manager menubar, under Layer
Manager -> Raster -> Hydrologic Modeling. I looked into [0], but clicking
"GUI" and "Interfaces" gives me "404 Not Found" error. So, I am trying to
discovered that I probably should add the string "Network Modeling" in the
file file gui/wxpython/menustring.py but I still don't have clear where I
should add the third level menu, the event and the binding function .. I
feel a bit lost.
This is generated during compilation process, edit
gui/wxpython/xml/menudata.xml instead.
Also, I don't understand where is located the wxGUI for each command. I
mean, for example typing r.watershed in the terminal raises the GUI.. where
It's generated on the fly by menuform.py based on `command
--interface-description`.
