[GRASS-dev] Hardlinking raster map files
Dears,
before creating the HPC related Wiki,
I would like to ask for your advise on hard-linking raster maps files.
Soeren suggested this as a tip, I understand to save time and space.
Hard-linking was also mentioned inside the JEODPP (JRC) team at some point.
I have implemented hard-linking raster maps in https://gitlab.com/NikosAlexandris/r.internal.sh.
It's a shell script, does not compile. Will convert in Python, if useful.
If you hard-link files, how do you perform it?
If of your interest, what do you think about it?
What would be important considerations to pay attention to?
Would you name such a module differently?
Would you consider soft-linking in addition or instead of?
Would you add a "dry-run" option (as in "don't do anything, just show what you want to do")?
Thank you, Nikos
NikosAlexandris wrote
Dears,
point.
Thank you, Nikos
grass-dev mailing list
grass-dev@.osgeo
https://lists.osgeo.org/mailman/listinfo/grass-dev
signature.asc (235 bytes)
<http://osgeo-org.1560.x6.nabble.com/attachment/5365206/0/signature.asc>
Would this be portable to other operating systems than linux Like e.g.
windows?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
* Helmut Kudrnovsky <hellik@web.de> [2018-05-22 23:54:32 -0700]:
Dears,
point.
Thank you, Nikos
grass-dev@.osgeo
&lt;http://osgeo-org.1560.x6.nabble.com/attachment/5365206/0/signature.asc&gt;
windows?
I wouldn't know, it depends (also) on the underlying file system.
While it works for my purpose, I would like to avoid common wrong-doings.
Reading about it (Wikipedia and else), I understand that it is doable.
The Python 2 function `os.link()` [0] is marked with
"Availability: Unix.". I don't know how easy it is to implement it.
Support for Windows was added after 3.2 [1]. I guess it concerns
NTFS.
[0] https://docs.python.org/2.7/library/os.html?highlight=os%20link#os.link
[1] https://docs.python.org/3.5/library/os.html?highlight=os.link#os.link
I regret for not writing in Python. It seems to me harder to implement
and maintain such a in Bash. Will convert for sure as soon as I find the time.
Cheers, Nikos
