I don't often get a chance to have input to hard core code development so this may be a naive request, but...
can I enter a request for error messages generally, and from the catch code being discussed in particular, that are verbose and provide some indication of the likely source of the problem. Or when the source could be a variety of things, a list of possible problems?
Jerry
---- Original message ----
Date: Sun, 29 Apr 2007 23:01:15 +0100
Subject: Re: [GRASS-dev] figuring out fonts - part 2
To: Michael Barton <michael.barton@asu.edu>
Cc: GRASS developers list <grass-dev@grass.itc.it>Michael Barton wrote:
It is a good thing that GRASS has a set of fonts that can be guaranteed to
be present, regardless of the system. These are the venerable stroke fonts.
But these fonts are ugly and hard to read. Romans just doesn¹t stand out
well in a scale or legend, for example, unless against a white background
and even then it is not clear at a distance for presentations.So here is a question. Can GRASS ship with a better set of fonts? Can it
come with a minimal TrueType set, for example, that could be guaranteed
present regardless of the system? Or is this technically not realistically
feasible?Support for TrueType fonts requires the FreeType library, which is
currently an optional dependency.That aside, most people will already have the Luxi font from the X.org
packages.--
Glynn Clements <glynn@gclements.plus.com>_______________________________________________
grass-dev mailing list
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
