I’m trying to do a script that calls g.copy
I want the user to be able to select which type of data to copy. So instead of specifying:
grass.run_command(‘g.copy’, rast=‘%s,%s’ % (input, output))
I’d like to something equivalent to:
grass.run_command(‘g.copy’, ‘%s=%s,%s’ % (datatype, input, output))
where datatype is the form of grass data to copy (eg, rast, vect, etc)
The way I’d like to do this doesn’t work. So what is the correct syntax here?
Thanks
Michael
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sun, Sep 2, 2012 at 11:04 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
I'm trying to do a script that calls g.copy
of specifying:
grass.run_command('g.copy', rast='%s,%s' % (input, output))
I'd like to something equivalent to:
grass.run_command('g.copy', '%s=%s,%s' % (datatype, input, output))
The way I'd like to do this doesn't work. So what is the correct syntax
here?
Create a dictionary first:
dataType = 'rast'
params = {dataType: '%s,%s' % (input, output)}
grass.run_command('g.copy', **params)
Maybe someone comes up with something better but this works.
Anna
Thanks
Michael
____________________
C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
Thanks much!!!
Michael
C. Michael Barton
On Sep 2, 2012, at 2:22 PM, Anna Kratochvílová <kratochanna@gmail.com>
of specifying:
here?
dataType = 'rast'
Anna
Thanks
Michael
C. Michael Barton
grass-dev Info Page
Note that it isn't necessary to format the argument yourself;
run_command will do this for you, so you just need;
grass.run_command('g.copy', rast = (input, output))
The way I'd like to do this doesn't work. So what is the correct syntax here?
grass.run_command('g.copy', **{datatype: (input, output)})
