[GRASS-dev] how to start wx vdigit?
I'm testing a possible solution to compiling the wx vdigit on OSX, but I can't figure out how to start it.
In the wx gui, Vector->Develop vector map->Digitize vector map runs the TclTk v.digit, not the wxpython digitizer. I have my vdigit test built and it looks like it's installed (etc/wxpython/vdigit/_grass6_wxvdigit.so and grass6_wxvdigit.py). I don't see anything in bin/ or scripts/ that looks like it might run vdigit.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
there currently two ways
1) add vector map layer into the layer tree, right click and from
contextual menu choose 'Start editing'
2) select in Map display window toolbar 'Digitize' (the last tool in
the toolbar), then from enabled vdigit toolbar choose vector map layer
you want to edit (this map must be present the current layer tree). I
remember there was bug on Mac connected to wxComboBox inside wxToolbar
instance. So maybe you cannot see these comboboxes in the toolbars.
Then first way should work for you.
Martin
2008/3/9, William Kyngesburye <woklist@kyngchaos.com>:
- Marvin
grass-dev mailing list
grass-dev@lists.osgeo.org
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
OK, here's what I got:
I wanted to start with an empty vector map, so I tried to create one from the GUI. Error in console:
   File "/Applications/GRASS-6.3.app/Contents/MacOS/etc/wxpython/wxgui.py", line 433, in OnMenuCmd
     menuform.GUI().ParseCommand(cmd, parentframe=self)
   File "/Applications/GRASS-6.3.app/Contents/MacOS/etc/wxpython/gui_modules/menuform.py", line 1390, in ParseCommand
     get_dcmd=get_dcmd, layer=layer)
   File "/Applications/GRASS-6.3.app/Contents/MacOS/etc/wxpython/gui_modules/menuform.py", line 608, in __init__
     mainFrame=self)
   File "/Applications/GRASS-6.3.app/Contents/MacOS/etc/wxpython/gui_modules/menuform.py", line 1050, in __init__
     txt3.SetValue(p['value']) # parameter previously set
   File "/BinaryCache/wxWidgets/wxWidgets-11~57/Root/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python/wx-2.8-mac-unicode/wx/_controls.py", line 2249, in SetValue
TypeError: in method 'SpinCtrl_SetValue', expected argument 2 of type 'int'
So I used v.edit from the Terminal to create one.
Now, added to the GUI display list, right-click (yes, the toolbar combo box is not there), start editing, and I get a dialog:
Unable to initialize display driver, see README file for more info.
Details: 'NoneType' object has no attribute 'OpenMap' (dynamic module does not define init function (init_grass6_wxvdigit))
It looks like the vdigit toolbar appears, and stays up, but the display list contextual menu still says "start editing" (stop is disabled), so it's probably not fully initialized, as the error says.
I'm not sure if this is from the way I setup my test build or something else.
Here is what I did to get it compiled: since _gdi_.so is technically an extension to [wx]Python, I figure that it should get loaded (maybe automatically?) by wxPython. So instead of directly linking it into vdigit, I used an OSX linker flag "-undefined dynamic_lookup" to tell the linker that the gdi.so symbols will be found at runtime.
But, I'm not sure it gdi is guaranteed to be loaded. Maybe it needs something in the vdigit code to trigger loading the extension, equivalent to import in Python code? Or maybe import it in grass6_wxvdigit.py, before importing _grass6_wxvdigit.so?
On Mar 9, 2008, at 1:26 PM, Martin Landa wrote:
Martin
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
     mainFrame=self)
'int'
Now fixed in trunk, http://trac.osgeo.org/grass/changeset/30510
important is the last part of the message which comes when you try to
import grass6_wxvdigit Python module .
Try:
cd gui/wxpython/vdigit
python
you will get this error
The problem is loading python module itself.
something else.
Hm, the last days I have not so much time to work on this, the way you
suggest maybe could solve it.
Martin
Yep, works now.
Try:
python
So is there a bug in grass6_wxvdigit.py?
something else.
I'm guessing "import wx" should import _gdi and load _gdi_.so, since _core imports _gdi. Didn't help with the init_grass6_wxvdigit error.
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
Oops, forgot the -shared flag in the vdigit makefile. It ended up linking as a program. See: http://trac.osgeo.org/grass/ticket/61
Changed the shared flag to something appropriate for OSX, and I didn't need to add the "import wx" to grass6_wxvdigit.py.
I successfully digitized a boundary. Lots of messages in the Terminal - failed assertions and context errors.
I'll add to http://trac.osgeo.org/grass/ticket/58 with my results.
Try:
python
something else.
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
Hi William,
[snip]
yes, it should work, I have tried few days ago but I always get error
something like
grass6_wxvdigit.so: undefined symbol: _ZN10wxPseudoDC9AddToListEP5pdcOp
Can you send me your Mac-related Makefile for inspiration?
Thanks, Martin
I put bits of what I did in:
On Mar 10, 2008, at 6:59 AM, Martin Landa wrote:
Hi William,
something like
Thanks, Martin
