[GRASS-dev] how to work on wxGUI?
Hello,
I would like to perform some work on wxPython GUI Dialogs.
What is the recommended way to edit the python files?
Do I need to complie GRASS in order to see the changes?
Is there a possibility to run the GUI locally from the source directory?
Best regards,
Timmie
No; you can edit the installed files directly.
Once GRASS has been compiled, you can run the copy in dist.<arch>
(within the source directory) via the bin.<arch>/grass64 script.
