[GRASS-dev] i.atcorr don't compile
the module i.atcorr in 6.4svn and 7svn don't compile (debian wheezy - 64 bit).
With make in the mail folder I have not error.
With make in i.atcorr folder I've this log:
http://dpaste.com/hold/623443/
Alfredo
On Thu, Sep 29, 2011 at 4:57 PM, Alfredo Alessandrini
<alfreale74@gmail.com> wrote:
(for the list record, since Anne solved it offlist already)
You need to configure GRASS with --with-cxx to enable the compilation
of i.atcorr.
of i.atcorr.
Should this be enabled by default?
With libraries, there's at least a possibility that the user might
infer that a particular module will need the appropriate --with-*
flag. But there's no clue as to which modules are written in C++.
While we're on the subject, can we choose a preferred file extension
for C++? There's no valid reason for needing duplicate sets of make
rules for both .cc and .cpp (and also .cxx, .c++ and/or .C if someone
ever uses those).
2011/9/29 Glynn Clements <glynn@gclements.plus.com>:
of i.atcorr.
I would say 'yes'.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On Thu, Sep 29, 2011 at 10:28 PM, Glynn Clements
of i.atcorr.
Yes, why not.
Exactly. We were initially in the dark, why i.atcorr didn't come up
while no error was reported.
ever uses those).
GDAL uses .cpp. Also others - a quick local poll on my dev machine:
[neteler@north ~]$ locate '.cpp' | wc -l
14213
[neteler@north ~]$ locate '.cc' | wc -l
834
[neteler@north ~]$ locate '.cxx' | wc -l
672
I'd vote for .cc|.cxx -> .cpp
2011/9/29 Markus Neteler <neteler@osgeo.org>:
personally I prefer `.cpp`.
Martin
14213
834
672
Probably influenced by MSVC/DevStudio using .cpp.
Done in r48562 (modify libiostream, r.terraflow, wximgview, xganim to
use .cpp instead of .cc) and r48563 (remove the *.make rules for .cc).
>> of i.atcorr.
Yes, why not.
Done in r48564.
