[GRASS-dev] i.pr in GRASS6.4
Greetings all
I've seen a few emails, at GRASS users mailing list regarding i.pr module. This module, developed for GRASS5 by Stefano Merler , is a multi-tool to perform Classification for a wide set of methods. This is a good asset for GRASS having this tool "fully working" on GRASS 6.4.
has anyone tried to "redone" this tool to GRASS6.4.?
Thank you so much for your help
Best regards,
Antonio Rocha
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5123 (20100518) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
yes, it can be found in GRASS addons SVN:
  http://grass.osgeo.org/wiki/Addons#i.pr
(raster & imagery modules typically only need a new Makefile to be ported
from GRASS 5 -> 6; anything written for grass 6.0.0 should still work
with any other GRASS 6.x.y, including GRASS 6.4.0rc6, without changes)
Hamish
Hi Hamish...
I have just installed using available Makefiles and it compiled.
The only major problem has to do with a Visualization. It opens an Xterminal but no raster is displayed. Was anything changes regarding this issue?
Thanks
Antonio
Hamish
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5124 (20100518) __________
http://www.eset.com
http://www.eset.com
I'm sorry but I need to make a correction regarding this. This was done for GRASS6 so Makefiles will be similar to the ones that GRASS6.4 has.
Ok I have downloaded i.pr into my LINUX (Ubuntu machine) and I've used this command to compile:
sudo make -C i.pr MODULE_TOPDIR=/usr/local/grass-6.4.0svn &>log.log
Attached to this email is the installation LOG. I had a few errors, regarding Description.html but how is the rest? OK?
(will it work on GRASS6.4?)
Thank you
best regards,
Antonio Rocha
António Rocha wrote:
Greetings all
Best regards,
Antonio Rocha
http://www.eset.com
Ups forgot the attachment.. Sorry
All executables were created...
Thank you
best regards,
Antonio Rocha
Greetings all
Best regards,
Antonio Rocha
http://www.eset.com
(attachments)
log.log (28.2 KB)
The MAN manual building script is either not existing on
your machine or perl fails:
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0svn sh /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man /usr/local/grass-6.4.0svn/docs/html/i.pr.blob.html /usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1 1
sh: Can’t open /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
make[3]: *** [/usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1] Error 2
That’s harmless for the usage.
For the rest, there are warnings which should ideally be fixed but
warnings are not necessarily errors.
Perhaps you would just try the tools?
