[GRASS-dev] images2gif.py in grass
I'm currently developing new tool for animation (wxpython-based
replacement of wxwidgets-based xganim, coming soon to addons) and I
would like to include the possibility to export the animation not only
as a sequence of images. It seems to me that the easiest possibility
is to use script images2gif.py [1] for creating animated gif, which is
under BSD license. Would it be possible to have it in grass?
Anna
[1] http://visvis.googlecode.com/hg/vvmovie/images2gif.py
Ahoj Anna,
On Tue, Oct 16, 2012 at 3:20 PM, Anna Kratochvílová <kratochanna@gmail.com> wrote:
I’m currently developing new tool for animation (wxpython-based
Wow, looks a great addition.
As far as I can undestand, the BSD license is not fully compatible with GPL unless it is either the New BSD License/Modified BSD License or the Simplified BSD License/FreeBSD License, which have been verified as GPL compatible by FSF [1]. Maybe you could consider to use ImageMagik instead, which is released under Apache 2 license, which seems compatible with GPL3 [3].
Anyhow I’m not an expert and maybe someone may correct me if I’m wrong.
madi
[1] http://en.wikipedia.org/wiki/BSD_licenses
[2] http://www.imagemagick.org/script/license.php
[3] http://www.apache.org/licenses/GPL-compatibility.html
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Forest Resources and Climate
I-21020 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
2012/10/16 Margherita Di Leo <dileomargherita@gmail.com>:
Ahoj Anna,
Hi
[3].
Anyhow I'm not an expert and maybe someone may correct me if I'm wrong.
Yes you are wrong... Your first link answer the question, "New" BSD
is compatible with GPL, Anna you can use images2gif.py
madi
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Hi Anna,
i would prefer to convert the images in a "real" video format to avoid
the limitations of GIF.
Maybe you could try to use PyMedia[1],[2] (well, its pretty old) or
utilize mencoder[3] to create the videos?
[1] http://pymedia.org
[2] http://pymedia.org/tut/src/make_video.py.html
[3] mencoder 'mf://*.png' -mf type=png:fps=10 -ovc lavc -lavcopts
vcodec=wmv2 -oac copy -o animation.avi
Best regards
Soeren
2012/10/16 Anna Kratochvílová <kratochanna@gmail.com>:
Anna
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Luca
Ahoj Anna,
Hi
[3].
Yes you are wrong…
Yes you are right and I’m happy to be wrong, I completely missed the (new) … :smiley:
Your first link answer the question, “New” BSD
madi
ciao
Luca
www.lucadelu.org
Margherita DI LEO
Hi Soeren,
gif is a nice simple option how to present 'moving images'. It is
widely supported and we don't need any external dependency in case of
using images2gif.py. I would like to see this option even if we were
able to export a real video.
Vaclav
On 16 October 2012 15:42, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Hi Anna,
Best regards
Soeren
Anna
2012/10/16 Sören Gebbert <soerengebbert@googlemail.com>:
creating video output, eg. using `mencoder` could be added later
(another dependency, will not work on Windows). I would suggest to
start with something which will work on all supported platforms
without any extra dependency (which seems to be `images2gif`).
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
2012/10/16 Vaclav Petras <wenzeslaus@gmail.com>:
agreed, Martin
2012/10/16 Martin Landa <landa.martin@gmail.com>:
Hi
agreed, Martin
me too...
ciao
Luca
www.lucadelu.org
Where should this script be placed? It could be a grass module,
however I need to call the writeGif function directly to avoid saving
images to disk (writeGif accepts PIL images).
Anna
i hope i do not start a flame war. :slight_smile:
agreed, Martin
IMHO animated GIF's have so many limitations i wouldn't support it for
GIS related map animations at all. The results will be to horrible.
Some arguments against it:
* Very small color range support: 8 bit per pixel == 256 colors for a picture
* True color is only supported when creating 256 bit tiles in a single picture,
  each tile can use different parts of a 24 bit RGB color space
* Only suitable for small animations and low-resolution film clips
* No control over animation frame rate/animation flow/pausing while
playing GIF's
Best regards
Soeren
playing GIF's
these limitations should be noted in the manual (please Anna), but
it's not the reason why the tool developed by Anna shouldn't support
animated GIF output. Of course support for video output is very
important, and should be implemented in some way (probably with extra
dependency, eg. mencoder or so).
Martin
Hi Sören,
On Tue, Oct 16, 2012 at 4:15 PM, Sören Gebbert <soerengebbert@googlemail.com> wrote:
gif is a nice simple option how to present ‘moving images’. It is
widely supported and we don’t need any external dependency in case of
agreed, Martin
IMHO animated GIF’s have so many limitations i wouldn’t support it for
  • Very small color range support: 8 bit per pixel == 256 colors for a picture
  • True color is only supported when creating 256 bit tiles in a single picture,
  • Only suitable for small animations and low-resolution film clips
  • No control over animation frame rate/animation flow/pausing while
    playing GIF’s
GIF’s have also pro’s, for example I use them in presentations, they usually are more handy to show than videos, you can just add them as images. Of course the option to export regular video as well, if technically possible, would be a plus.
Ciao madi
Margherita DI LEO
On Tue, Oct 16, 2012 at 4:23 PM, Margherita Di Leo
<dileomargherita@gmail.com> wrote:
Hi Sören,
> Hi,
> agreed, Martin
picture,
playing GIF's
GIF's have also pro's, for example I use them in presentations, they usually
would be a plus.
The gif output would be something you get quickly and easily and it's
ideal for presentations (as Madi said). I would also export the
sequence of images to let the 'advanced' users make anything what they
want.
Anna
Ciao madi
Margherita DI LEO
