I tried to implement drop column into DBF driver to get
rid of columns like 'cat_' when re-importing an exported map:
echo "ALTER TABLE mymap DROP COLUMN cat_" | db.execute
Attached the changes to lib/db/sqlp/ and /db/drivers/dbf/
The idea is to load the table internally in SQLP_DROP_COLUMN
(such as SQLP_ADD_COLUMN does) but to jump over the column
which we want to drop.
So I took load_table() and made it load_table_selective(),
most likely in an ugly way.
While ugly, it could work but apparently I never reach
SQLP_DROP_COLUMN. It bails out with
D3/3: sql: ALTER TABLE mymap DROP COLUMN cat_
D3/3: SQL statement parsed successfully: ALTER TABLE mymap DROP COLUMN cat_
D3/3: add_column(): tab = 11, type = 3, name = edg_id, width = 20, decimals = 6
D3/3: Doing SQL command <8> on DBF table... (see include/sqlp.h)
dbmi: Protocol error
D2/3: G__home home = /home/neteler
ERROR: Error while executing: "ALTER TABLE mymap DROP COLUMN cat_
Check st->nCol and whether st->Col[0] exist at the time you call
load_table_selective. It seems that the bang happens around the point
you call the function; the sqpAddColumn should have put your colname
there, but...
Daniel.
On 12/4/06, Markus Neteler <neteler@itc.it> wrote:
I have tried to solve this problem. I think in a very ugly way, but it
seems to work (see the attached patch).
Regards, Martin
2006/12/4, Markus Neteler <neteler@itc.it>:
nice, I have tested it successfully (DBF driver).
Also written v.db.dropcol and tested that with DBF and PG
driver.
Once you changes are in CVS, I'll submit v.db.dropcol.
Still it would be good to have more people testing the
proposed patch.
Thanks
On Fri, Feb 02, 2007 at 05:35:19PM +0100, Martin Landa wrote:
Regards, Martin
>Hi,
>decimals = 6
>I have no clue why. Help is welcome.
>Thanks,
>Markus
the patch has been committed to CVS. It would be nice if more users test it...
Best regards, Martin
2007/2/2, Markus Neteler <neteler@itc.it>:
Martin,
driver.
proposed patch.
Thanks
> Hi,
> Regards, Martin
> >Hi,
> >decimals = 6
> >Thanks,
> >Markus
