Markus Neteler <neteler@osgeo.org> writes:
>> The following functions are declared in include/vect/dig_externs.h
>> (as of a recent SVN checkout), yet there're no trace of their
>> definitions in the source.
> Navigating in the old code there will be the rest.
I guess, there're more long dead prototypes to be found.
> If no longer existing, I vote for removal from GRASS 6/7.svn.
I've applied the patch below to the recent SVN trunk and the
code seems still to compile without a note on these.
Unless there'll be any objections, I'm going to apply the patch
below to the trunk.
What SVN branch should I merge this one to for GRASS 6?
--- include/vect/dig_externs.h (revision 36440)
+++ include/vect/dig_externs.h (working copy)
@@ -35,9 +35,6 @@
plus_t *dig__long_convert_to_plus_t(long *, plus_t *, int, struct dig_head *);
char *dig__convert_buffer(int);
-plus_t **dig_get_cont_lines(struct Map_info *, plus_t, double, int);
-plus_t dig_get_next_cont_line(struct Map_info *, plus_t, double, int);
struct dig_head *dig_get_head(void);
struct dig_head *dig__get_head(void);
void dig_init_portable(struct Port_info *, int);
@@ -119,8 +116,6 @@
void dig_free_plus_isles(struct Plus_head *);
void dig_free_plus(struct Plus_head *);
int dig_load_plus(struct Plus_head *, GVFILE *, int);
-int dig_map_to_head(struct Map_info *, struct Plus_head *);
-int dig_head_to_map(struct Plus_head *, struct Map_info *);
int dig_spindex_init(struct Plus_head *);
/* int dig_snap_line_to_node (struct Map_info *, int, int, struct line_pnts *); */
@@ -138,9 +133,6 @@
/* int dig_node_del_line (struct Plus_head *plus, int node, int line);
int dig_add_line_to_node (int, int, char, struct Map_info *, struct line_pnts *); */
-int dig_point_to_area(struct Map_info *, double, double);
-int dig_point_to_next_area(struct Map_info *, double, double, double *);
-int dig_point_to_line(struct Map_info *, double, double, char);
/* list of updated */
void dig_line_reset_updated(struct Plus_head *Plus);
@@ -194,12 +186,7 @@
int dig_read_cidx(GVFILE *, struct Plus_head *, int);
/* int dig_in_line_bbox (P_LINE *, double, double); */
-int dig_check_dist(struct Map_info *, int, double, double, double *);
-int dig__check_dist(struct Map_info *, struct line_pnts *, double, double,
- double *);
/* int dig_center_check (P_LINE *, int, int, double, double); */
-int dig_point_by_line(struct Map_info *, double, double, double, double,
- char);
/* int dig_by_line_bbox (P_LINE *, double, double, double, double); */
int dig_prune(struct line_pnts *, double);
int dig_write_head_ascii(FILE *, struct dig_head *);
FSF associate member #7257
