[GRASS-dev] inverted color scales
What do you guys think of a flag in r.colors to apply an inverted color scale?
cheers
Carlos Henrique Grohmann - Guano
Visiting Researcher at Kingston University London - UK
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
“Good morning, doctors. I have taken the liberty of removing Windows 95 from my hard drive.”
–The winning entry in a “What were HAL’s first words” contest judged by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Carlos "Guâno" Grohmann wrote:
What do you guys think of a flag in r.colors to apply an _inverted_ color
scale?
Sounds really usefull to me.
Maciek
I have been wanting this feature for a while!
thanks Carlos!
Dylan
> scale?
Maciek
grass-dev mailing list
grass-dev@grass.itc.it
> scale?
Sounds really trivial to implement, too.
"struct Colors" already has an "invert" field, which can be inverted
with G_invert_colors().
AFAICT, you just need e.g.:
    flag.n = G_define_flag();
    flag.n->key = 'n';
    flag.n->description = _("Invert colors");
    if (flag.n->answer)
  G_invert_colors(&colors);
  colors = colors_tmp;
The only issue is whether the inversion should come before or after
logarithmic scaling (I think that it matters, although I haven't
actually checked).
As more transforms are added, it's looking more important to replace
the various flags with an option, e.g. trans=log,eq,inv.
NOTE: this will add another situation where the GUI's assumption that
opt->multiple=YES implies a set (rather than a list) will fail.
> > _inverted_ color scale?
I've wanted this for a long time too.
Glynn:
    flag.n->key = 'n';
    if (flag.n->answer)
[//] colors = colors_tmp;
done in 6.3 CVS.
actually checked).
I think that it matters too, and I put it before the scaling.
(flipping it is conceptually a linear operation, don't apply a linear
operation to log-transformed data; or if you prefer, keep the rule defn
code separate from the math post-processing code)
Hamish
Glynn:
> flag.n->key = 'n';
> if (flag.n->answer)
Nope; unlike the other transformations, G_invert_colors() operates
"in-place" (it simply inverts the "invert" flag in the structure).
In the above, colors_tmp essentially contains garbage; it may not have
even been initialised.
