Hello list,
does a link exist to a simple installation for GRASS 8 on Linux Mint? I just tried to install and I get a lot of confusing ‚broken packages‘ messages, so I cannot install.
Thanks for help,
Uwe
Hello list,
Thanks for help,
Uwe
On my personal laptop last night for Linux Mint 21.1, I just followed the compilation instructions for the source at https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu for Ubuntu 20.04 ( adding --with-pdal to the configuration script ) and had no problems compiling from the current main tree ( probably doing the 8.2 release branch would be better) . Make but don’t make install. You can make a launcher on the desktop in Linux Mint that points directly to the compiled binary . This makes it somewhat easy to have different versions of GRASS compiled for comparison.
This is probably more than you wanted to know and does not help with your issue of conflicts with the precompiled binaries, but it works and I personally thought it was pretty nifty.
To address your issue, You might try adding the Ubuntu GIS ppa, https://wiki.ubuntu.com/UbuntuGIS https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable .
Doug
From: grass-dev grass-dev-bounces@lists.osgeo.org on behalf of gisfisch@t-online.de gisfisch@t-online.de
Sent: Tuesday, January 10, 2023 7:23 AM
To: grass-dev@lists.osgeo.org grass-dev@lists.osgeo.org
Subject: [EXTERNAL] [GRASS-dev] Link to installation
This email has been received from outside of DOI - Use caution before clicking on links, opening attachments, or responding. |
Hello list,
Thanks for help,
Uwe
