Markus,
your recent change in the Makefile of r.out.tiff causes compilation to fail for me:
~/SRC/GRASS/grass6/raster/r.out.tiff$ make
make /home/mlennert/SRC/GRASS/grass6/dist.i486-pc-linux-gnu/docs/html/r.out.tiff.html HTMLSRC=/home/mlennert/SRC/GRASS/grass6/dist.i486-pc-linux-gnu/bin/r.out.tiff
make[1]: entrant dans le répertoire « /home/mlennert/SRC/GRASS/grass6/raster/r.out.tiff »
make[1]: *** Pas de règle pour fabriquer la cible « /home/mlennert/SRC/GRASS/grass6/dist.i486-pc-linux-gnu/docs/html/r.out.tiff.html ». Arrêt.
make[1]: quittant le répertoire « /home/mlennert/SRC/GRASS/grass6/raster/r.out.tiff »
make: *** [htmlcmd] Erreur 2
Reverting to the previous version makes it compile again.
Moritz
Moritz,
ok - reverted. If you come across another one cause by me,
please revert directly in CVS. It seems that Makefile rules
remain mysterious for me
I got inspired by
http://grass.itc.it/pipermail/grass-commit/2007-October/030502.html
Moritz Lennert-2 wrote:
Markus,
fail for me:
make
». Arrêt.
Moritz
View this message in context: http://www.nabble.com/Makefile-change-in-r.out.tiff-tf4630721.html#a13228375
Sent from the Grass - Dev mailing list archive at Nabble.com.
I got inspired by
You moved it one line too far; PGM must be set before including
Module.make.
In general, the point at which variables get defined doesn't matter if
they are only used in commands, but it matters if they are used in the
dependency line.
Essentially, dependency lines get expanded at the point they are read,
while commands are expanded at the point they are executed.
AFAICT, the list of variables where the order is significant is:
PGM
LIB_NAME
SUBDIRS
CMD_OBJS
LIB_OBJS
LOCAL_HEADERS
EXTRA_HEADERS
DEPENDENCIES
