[GRASS-dev] message standardization on wiki
Can I suggest the following rules
1. First letter should be capitalized
2. Use present tense (cannot instead of could not)
3. No contractions (cannot instead of can't)
4. Good sentence construction ("Cannot find input map <%s>" instead of "It could not be find input map <%s>")
5. Be consistent with periods. Either end all phrases with a period or none.
Jerry
---- Original message ----
Date: Wed, 11 Apr 2007 15:07:21 +0200
Subject: [GRASS-dev] message standardization on wiki
To: grass-dev <grass-dev@grass.itc.it>, translations@grass.itc.it
updating Czech translation of GRASS I am suggesting some of standard
messages. There are lot of library functions which are very often used
(e.g. G_find_cell2() or G_find_vector2()), but messages are *very*
different, see
http://grass.gdf-hannover.de/wiki/Development_Specs#Messages_Discussion
Please feel free to extend the list of "standard messages", correct
existing (cannot -> could not?, ...), etc. then I will be happy to
change messages in GRASS code according this proposal.
http://grass.gdf-hannover.de/wiki/Development_Specs#Standard_messages_sandbox
also
http://grass.gdf-hannover.de/wiki/Development_Specs#How_should_Errors.2FWarnings.2FMessages_be_formatted
Not important, but really pain for GRASS translators...
Martin
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
grass-dev mailing list
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
I would prefer not using "Cannot...". It's bad grammar. I would much
prefer "Unable to..." or something to that effect.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
While I can see your point, that construction is quite common in error
messages, e.g.:
  $ ls -l foo
  ls: cannot access foo: No such file or directory
Neither "cannot ..." nor "unable to ..." form complete sentences.
If you're concerned about grammar, you can provide an explicit subject
("The program cannot ..."), or use the third person (e.g. "The file
cannot be found").
Personally, I don't have a problem with just omitting the subject.
messages, e.g.:
  $ ls -l foo
cannot be found").
Point taken. I was really referring to the usage of "Cannot". Some
dictionaries do not recognize it as 'real word', yet others (that are
generally more progressive with slang and contractions) say that it
should replace "can not" in modern English.
It's a non-problem. In modules I've [re]written, I've used "Unable to",
but I can go back and change them for consistency.
