[GRASS-dev] Mini project 2023: Week 5: Improving Single-Window GUI user experience
Hello guys,
I am sending my fifth report regarding the GRASS mini-project which is also available here: [1].
1) What did I complete this week?
The PR [2] implementing the Export history button in the Console pane was merged.
The first part of the week I worked on PR [3] which adds an input prompt sign to the command prompt widget. However, although it was our suggestion from [4], the intervention into the command prompt showed programmatically as very unfortunate - it was really hard to cover all cases of how the text in the command prompt could be managed. So, we decided to implement the task differently by showing a hint in the case that the command prompt is not focused. I think it is an even more user-friendly solution. It is already prepared for merging (see [5]).
Meanwhile, I worked on adding “isDocked” parameter to workspace handling in the PR [6] dealing with dock/undock map display functionality. It was the thing I forget to consider. However, the workspace issue revealed an error in [6] related to closing undocked map display frame.
2) What am I going to achieve for next week?
The goal for the next week is to merge both - [5] and [6]. Then I plan to create a PR on the Console reorganization according to the suggestion in [4].
3) Is there any blocking issue?
There is one blocking error in [6] related to the closing of undocked map display frame (wrapped C/C++ object of type MapPageFrame has been deleted). I have already spent several hours to fix it but unsuccessfully. I will probably put it off now and go back later, with more ideas in my mind.
Have a nice week,
Linda
[1] https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/ImprovingSingleWindowUX
[2] https://github.com/OSGeo/grass/pull/2682
[3] https://github.com/OSGeo/grass/pull/2718
[4] https://github.com/OSGeo/grass/issues/2585
[5] https://github.com/OSGeo/grass/pull/2728
[6] https://github.com/OSGeo/grass/pull/2667
