[GRASS-dev] NASA to release no cost 30m DEMs with world-wide coverage on 29 June
See the following announcement. NASA (USA) will release high resolution DEM’s of the globe, produced from the Terra ASTER satellite, at no charge. You can check out the web announcement at <https://lpdaac.usgs.gov/lpdaac/about/news_archive/monday_june_22_20092>. As a Terra ASTER user, I’ve been using the DEM’s for several years and found them to be a very good high-resolution (30x30m) topography source.
Michael
================== announcement ====================
ASTER Global DEM
Following review of the validation results, METI and NASA have decided to jointly release the
ASTER GDEM on June 29, 2009. Previously, METI and NASA announced their intent to
contribute the ASTER GDEM to the Global Earth Observation System of Systems (GEOSS).
Upon release, the ASTER GDEM will be available at no charge to users worldwide via
electronic download from ERSDAC and from NASA’s Land Processes Distributed Active
Archive Center (LP DAAC) by visiting http://www.gdem.aster.ersdac.or.jp/
and https://wist.echo.nasa.gov/~wist/api/imswelcome/, respectively.
The ASTER instrument was built by METI and launched onboard NASA’s Terra spacecraft in
December 1999. The ASTER instrument uses the nadir-viewing and the backward-viewing
telescopes; together they enable along-track stereoscopic capability to generate stereo data with
a base-to-height ratio of 0.6. The spatial resolution is 15 m in the horizontal plane. One nadir-
looking ASTER VNIR scene consists of 4,100 samples by 4,200 lines, corresponding to about
60 km-by-60 km ground area.
The methodology used to produce the ASTER GDEM involved automated processing of the
entire 1.5-million-scene ASTER archive, including stereo-correlation to produce 1,264,118
individual scene-based ASTER DEMs, cloud masking to remove cloudy pixels, stacking all
cloud-screened DEMs, removing residual bad values and outliers, averaging selected data to
create final pixel values, and then correcting residual anomalies before partitioning the data into
1°-by-1° tiles. It took approximately one year to complete production of the beta version of the
ASTER GDEM using a fully automated approach.
The ASTER GDEM covers land surfaces between 83°N and 83°S and is composed of 22,600
1°-by-1° tiles. Tiles that contain at least 0.01% land area are included. The ASTER GDEM is
in GeoTIFF with geographic lat/long coordinates and a 1 arc-second (30 m) grid of elevation
postings. GDEM is referenced to the WGS84/EGM96 geoid. Pre-production estimated
accuracies for this global product were 20 meters at 95% confidence for vertical data and 30
meters at 95 % confidence for horizontal data. Initial validation studies concluded that the
ASTER GDEM generally meets the pre-production accuracy predictions, but results do vary
and include areas where GDEM accuracy does not meet the pre-production estimates**.**
Land surface topography is one of the most fundamental geophysical measurements of the
Earth, and it is a dominant controlling factor in virtually all physical processes that occur on the
land surface. Land surface topography also significantly controls processes within the
overlying atmosphere and reflects the processes within the underlying lithosphere.
Consequently, topographic information is important across the full spectrum of earth sciences,
and the availability of an up-to-date, high resolution (1-arc-sec or less) global DEM remains a
priority of earth scientists for a long time. The ASTER GDEM is expected to meet the
requirements of many users for global topographic information.
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies, School of Human Evolution & Social Change
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
I've tended to consider SRTM to have a slightly better vertical accuracy and ASTER DEM to have a better horizontal resolution. There are other differences too. ASTER DEMs are created using stereoscopic imagery (forward and backward band 3 near IR) and SRTM is radar. So ASTER DEMs are affected by clouds and by surface vegetation, and pretty much stop at the coast.
Michael
____________________
Phone: 480-965-6262
Fax: 480-965-7671
On Jun 26, 2009, at 12:48 AM, Micha Silver wrote:
Thanks, Michael. That's great news.
What do you make of the 20 m./30 m. vertical/horizontal accuracy statement?
Isn't SRTM supposed to be around 15 m. vertical and <10 m. horizontal
(even tho' it's 90 m. resolution)?
Micha
resolution DEM's of the globe, produced from the Terra ASTER
<https://lpdaac.usgs.gov/lpdaac/about/news_archive/monday_june_22_20092&gt;\.
As a Terra ASTER user, I'
Isn't SRTM supposed to be around 15 m. vertical and <10 m. horizontal (even tho' it's 90 m. resolution)?
Micha
See the following announcement. NASA (USA) will release high resolution DEM's of the globe, produced from the Terra ASTER satellite, at no charge. You can check out the web announcement at <https://lpdaac.usgs.gov/lpdaac/about/news_archive/monday_june_22_20092&gt;\. As a Terra ASTER user, I've been using the DEM's for several years and found them to be a very good high-resolution (30x30m) topography source.
Michael
Dear all,
Have someone accessed ASTER DEM today? According to the announcement, today these data will be available, but up to now I can’t find a way of get some sample DEM.
If you got success, please, drop us some lines with the “clips” steps.
Bests
milton
brazil=toronto
2009/6/26 Michael Barton <michael.barton@asu.edu>
Michael
ASTER Global DEM
Phone: 480-965-6262
Fax: 480-965-7671
grass-user mailing list
grass-user@lists.osgeo.org
