[GRASS-dev] New Mac OS X application build option
Finally got the Mac OS X build option into CVS, with a little configure/makefile help from Glynn.
To build GRASS as a Mac OS X application (exactly like my binaries, if anyone has used those), add these options to your configure command:
--prefix=/Applications --enable-macosx-app
Since the default prefix is /usr/local and it's nearly impossible to have multiple conditional default prefixes in configure, you should set the prefix as above.
It's tested with OSX 10.4 and the latest Xcode. It should work on 10.3, but it would be good to have verification of this if anyone cares to try it.
Enjoy!
William Kyngesburye <kyngchaos@kyngchaos.com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
Cheers to you and Glynn!
Michael
cares to try it.
Enjoy!
robot?
answer...
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
