Hamish wrote:
> I have added a new module, r.grow.distance, which generates a map
> where the value of each cell is the distance to the nearest non-null
> cell in the input map (similar to r.cost with a constant cost, except
> that you get real circles rather than approximations).
ie better than r.cost's knight's move / octagon. (?)
AFAICT, r.cost gives octagons without -k and hexadecagons (16 sides)
with -k.
Even if that's an adequate approximation, r.grow.distance is
noticeably faster, especially if the map won't fit into memory.
In the process of quantifying that, I found a bug in the way that
r.cost computes the number of segments:
if (maxmem > 0)
segments_in_memory =
2 + maxmem * (nrows / SEGCOLSIZE) * (ncols / SEGCOLSIZE) / 100;
else
segments_in_memory = 4 * (nrows / SEGCOLSIZE + ncols / SEGCOLSIZE + 2);
Because integer division rounds down, if the map is
one-point-something segments in each direction, it allocates 2+1*1 = 3
segments for a map which really needs 4.
[With "spearfish".]
$ g.region res=45
$ time r.cost -k --o start_rast=test input=one output=test.grow
318 rows, 423 cols
real 1m18.267s
user 0m2.876s
sys 1m15.358s
78 seconds, of which 75 is spent in the kernel (i.e. swapping segments
to file). At res=30 (spearfish's default), I Ctrl-C'd it after a
couple of minutes.
OTOH, with percent_memory=0 (4*(1+1+2) = 16 segments):
$ g.region res=45
$ time r.cost -k --o start_rast=test input=one output=test.grow percent_memory=0
318 rows, 423 cols
real 0m1.518s
user 0m1.477s
sys 0m0.040s
1.5 seconds. A significant improvement over 78 seconds.
Fixed in SVN trunk (r32239).
