[GRASS-dev] On (Landsat) imagery naming patterns
Greetings to the dev-list.
I successfully tested <i.histo.match>, by feeding it with 12 Landsat scenes
(working on identical bands, different Path/Row tiles) in one go. It works and
I really enjoy it.
However, there is some "problem":
<i.histo.match> wont accept the "." character as part of the image/raster map
names. This is an SQL restriction (thanks Luca D for the quick help) as the
module utilises sqlite internally for the calculations.
Although I am familiar with this restriction, due to pressing deadlines, I
overlooked that "point" while designing my workflow and decided to go for a
specific naming pattern for all Landsat scenes at each (pre-)processing step
(working currently on 25+ tiles, for summer and winter that cover the entire
Greek territory).
In addition, the respective manuals for modules like <i.landsat.toar>,
<i.landsat.acca>, <i.topo.corr> hold in their examples/descriptions (thus,
someone can easily interpret that these modules "encourage" the use of) names
like "B.", "B.toar", "toar.5", et.c.
I certainly like to keep, while on intermediate processing steps, long names
whose parts are separated by either the underscore character ( _ ) or the dot
character ( . ).
This is, from my point of view, an inconsistency which adds-up some confusion
-- especially to new users who will try/need to use <i.histo.match> at some
point.
As changing the module or adding internally a solution will add complexity, I
guess it is better to adhere to some kind of "strict" naming rules/patterns in
the manuals' examples, in the wiki and elsewhere?
In time I will try to propose new wording and examples for all Landsat related
modules/manuals I have used/read.
GRASS has (almost) everything required for a "perfect" Landsat processing
work-flow. This small inconsistency breaks the harmony :-).
Best, N
and I really enjoy it.
Could it be that histo-matching works nicely only on 0-255 ranges but doesn't
play nice in ranges 0-1.0? Integers only?
For example, when feeding images ranging from 0-1.0 (all Landsat bands 3) with
the optional parameter "max=1", many of the histo-matched images are "flatten"
to 1.
I will try to "recode" 0-1.0 images to 0-255 and repeat the histo-matching
process.
Best, Nikos
On Wed, Feb 20, 2013 at 3:27 PM, Nikos Alexandris
Yes, integers only. The i.histo.match script forces input raster
values to integers. But it might not be restricted to the 0-255 range.
to 1.
process.
For rescaling to 0-1000, you could try something like
r.mapcalc "bandX_int = round(1000 * bandX)"
HTH,
Markus M
Best, Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
Nikos Alexandris:
>> scenes (working on identical bands, different Path/Row tiles) in one go.
>> It works and I really enjoy it.
Nikos A:
> doesn't play nice in ranges 0-1.0? Integers only?
Oh how nice it would be to do the tranformation internally :slight_smile:
> with the optional parameter "max=1", many of the histo-matched images are
> "flatten" to 1. I will try to "recode" 0-1.0 images to 0-255 and repeat
> the histo-matching process.
Nice! But I wonder why round-ing is required? I want to jump back afterwards
(i.e. divide by 1000 the histo-matched images). Rounding does not hurt much,
does it?
Thank you Markus, Nikos
On Wed, Feb 20, 2013 at 4:19 PM, Nikos Alexandris
Nikos Alexandris:
rounding is not required, just a bit more accurate than truncating
with int(1000 * bandX).
Markus M
MM:
NA:
MM:
Great Wizard, thnx :slight_smile:
N
ps- note-to-self: add this in Wiki when writing about histogram matching of
Landsat reflectances.
Hmmm g.rename originalnname with newname (sed substitute “.” with “_” in originalname)
I agree this additional step is less elegant in the work flow
Y
On Feb 20, 2013 12:31 PM, “Nikos Alexandris” <nik@nikosalexandris.net> wrote:
I really enjoy it.
However, there is some “problem”:
<i.histo.match> wont accept the “.” character as part of the image/raster map
overlooked that “point” while designing my workflow and decided to go for a
Greek territory).
someone can easily interpret that these modules “encourage” the use of) names
like “B.”, “B.toar”, “toar.5”, et.c.
character ( . ).
– especially to new users who will try/need to use <i.histo.match> at some
point.
guess it is better to adhere to some kind of “strict” naming rules/patterns in
the manuals’ examples, in the wiki and elsewhere?
GRASS has (almost) everything required for a “perfect” Landsat processing
Best, N
On Wednesday 20 of February 2013 23:23:31 Yann Chemin wrote:
Hmmm g.rename originalnname with newname (sed substitute "." with "_" in
originalname)
Y
Hi Yann.
This is, of course, what I did/do for now. I can't change my naming pattern
now anyway. But I think as a long-term goal, the modules should follow
homogeneous naming conventions, as much as possible.
For the records, I use(d) in a script
tr "." "_"
as I have placed the "." as a separator everywhere. I hope this is not
dangerous.
Best regards, Nikos
It should be easy to make i.histo.match.py do name cleansing and
then back to the orginal, internally. It could make a table/
dictionary of map names vs. img_1, img_2, ... safe column names
then work with the safe names. Make the program[mer] do the hard
work, not the end user.. :slight_smile:
best,
Hamish
note-to-self: maybe that would be (another) good exercise for me (later, on
March)?
Note, <i.histo.match> itself adds a user-defined suffix which _always_ begins
with a "." :slight_smile:
thnx, Nikos
MM:
NA:
MM:
Just FYI, results look nice! I even convert back to 0-1.0 via
r.mapcalc --o "${HistoMatchedMap} = ${HistoMatchedMap} / 1000.0"
Thnx, Nikos
ps- I wonder if *10000 is *better* for higher precision?
0-1.0 via
depending on the sensor's 8-bitnesss or not, you can probably calculate by hand now many significant digits are useful. A little bit extra probably doesn't hurt.
1 / 2^8 = 0.00390625
Hamish
Jorge:
Hi, I quick review the code of i.landsat.* and the programms never use
the dot as a part of the output filenames.
The output names are construct as prefix+suffix not as
prefix+'.'+suffix. Then, the question is more on 'style' than on
programmation. The only change needed are in the HTML when a decission
is taken.
Right!
( I also wrote in the beginning:
Nikos A:
names like "B.", "B.toar", "toar.5", et.c.
It's just that people will likely use what the manuals suggest!
Another quick question: What is the better name to the Landsat 8? tm8 or
ot8 (from OLI/TIRS 8).
If my view counts a small little bit: "tm8" rings a bell like "thematic
mapper" which is maybe a bit confusing.
I used ot8 in the previous version send to Nikos
but before send to Markus it could be changed.
Sorry Jorge, don't have the time to test it now.
Thank you once again for your efforts Jorge :slight_smile:
Best, Nikos
doesn't hurt.
- Does this add up (practically a lot?) to the computational cost for "mortal"
machines?
And two more questions on <i.histo.match>:
- is there a reason, besides time, not to make <i.histo.match> understand
floating points?
- the algorithm implemented in <i.histo.match> does take Average pixel
values as reference(s) upon which all computations are based on for the histo-
matched values, right?
--%<--- lines 165 ~ 167 --- --- --- %<---
# calculate new value of pixel_frequency
        average = (tot/n_images)
        cHist = cHist + int(average)
thnx, Nikos
By the way, that was Landsat5!
doesn't hurt.
I didn't pay too much attention back then as I was under enormous time
pressure. But, I think I didn't miss much of the precision with respect to
the final product's scope. Except if the last 4 (or 3, can't remember) digits
make up a great deal when histo-matching.
Back to present. QuickBird is an 11-bit sensor [1] and data are delivered as
either 8-bit or 16-bit. In this case we have
1 / 2^11 = 0.0004882812
Does that say anything about the significant digits? I want to rescale
QuickBird bands in order to use'em with i.pansharpen. I am thinking to go
from Reflectance (double precision) to integer (as above, only this time I'd
multiply with a number as big as it takes to keep all decimals) and then
rescale to [0, 255].
Makes non-/sense? Any idea how many decimals should be preserved for
analysis? I might be hunting "fine digits" for nothing...
In any case, conversions from DNs to Reflectance should be done in a 32-bit
level [2] (that corresponds to: 1 / 2.328306e-10). The same is done with
Landsat imagery though both L5 and L7 data are delivered as 8-bit [3].
Nikos
[1] also mentioned in the document
<http://www.digitalglobe.com/downloads/QuickBird_technote_raduse_v1.pdf&gt;, page
7
[2] same document, page 8: "...conversion equations are to be
performed on all pixels in a given band of a QuickBird image and should use
32-bit floating point calculations."
[3] http://landsat.usgs.gov/how_is_radiance_calculated.php
