[GRASS-dev] On `svn propset`
Dears,
I copied over a "new" version of a python script (local) into the
'grass-addons' directory (which is the SVN repository). The `file`
command when run on the file in question, returns:
file r.estimap.recreation.py
r.estimap.recreation.py: Python script, UTF-8 Unicode text executable, with very long lines
I think I've correctly re-set the properties via
svn propset svn:eol-style "native" r.estimap.recreation.py
property 'svn:eol-style' set on 'r.estimap.recreation.py'
and
svn propset svn:mime-type text/x-python r.estimap.recreation.py
property 'svn:mime-type' set on 'r.estimap.recreation.py'
My question is: how do I tell the difference after having applied these
commands? `svn diff` or `svn status` don't show up anything?
Thank you, Nikos
Hi Nikos,
On Sun, Jan 13, 2019 at 1:10 PM Nikos Alexandris
<nik@nikosalexandris.net> wrote:
Dears,
and
Do you run that manually or use the helper script
grass-addons/tools/module_svn_propset.sh *
It should!
* Markus Neteler <neteler@osgeo.org> [2019-01-13 14:53:13 +0100]:
Manually. TL;DR
The properties seem to be already set and there is no need to re-set them.
Perhaps, once set for a file, in an SVN repository, there is no need for
a re-set? Even if actually replacing a file (instead of updating it)
with a file from a(nother) non-SVN repository, and committing the update.
What I did/tried:
# 1 : Print working directory
pwd /osgeo/grass-addons/grass7/raster/r.estimap.recreation
# 2 : Update (here == replace) the Python script
cp /some/local/repository/r.estimap.recreation.py /osgeo/grass-addons/grass7/raster/r.estimap.recreation/r.estimap.recreation.py
cp: overwrite '/osgeo/grass-addons/grass7/raster/r.estimap.recreation/r.estimap.recreation.py'? y
# 3 : committing the change to the SVN repository
svn ci -m "r.estimap.recreation.py: remove left-over 'd' flag" r.estimap.recreation.py
# which is: https://trac.osgeo.org/grass/changeset/73931
# 4 : I realise(d) I forgot to set the file properties
# 5 : Setting them manually and testing again
No effect!
# 5 : Trying to use the script:
sh ../../../tools/module_svn_propset.sh r.estimap.recreation.py
# No change again!
# 6 : From withing a GRASS GIS session maybe? Repeating the last two
# commands, does nothing.
# 7 : Last check
svn propget svn:mime-type r.estimap.recreation.py
text/x-python
svn propget svn:eol-style r.estimap.recreation.py
native
# How can this be? Properties are already set.
Nikos
On Sun, Jan 13, 2019 at 7:05 PM Nikos Alexandris
Manually. TL;DR
There is no harm to run the script. It saves you likely quite some time :slight_smile:
Trying that locally didn't change anything.
Question: what's wrong and you don't like? Maybe I don't get it...
* Markus Neteler <neteler@osgeo.org> [2019-01-13 19:38:30 +0100]:
Manually. TL;DR
I did. But I maybe I don't understand it well yet.
Nothing. Why? What I don't like perhaps is that I forget such details
and indirectly create work for others.
Thanks Markus, Nikos
On Sun, Jan 13, 2019 at 12:59 PM Nikos Alexandris <nik@nikosalexandris.net> wrote:
Good question. Subversion (as well as Git) does look at the content of the file not at the creation date or anything like that. Replacing a file is the same as modifying it from point of view of the common versioning control systems. (Renaming file is a different story.)
Vaclav
* Vaclav Petras <wenzeslaus@gmail.com> [2019-01-14 21:39:50 -0500]:
Perhaps related?
https://resources.collab.net/blogs/repository-dictated-configuration-part-2-of-3-autoprops
(referenced at https://stackoverflow.com/a/17562605/1172302)
Nikos
