Hello,
I am writing a Grass programm which creates a raster, reads the values of the raster map at certain points and creates a new rastermap having the same name as the old one.
I am using the function
G_open_cell_new() to overwrite the existing raster map.
and the function
G_close_cell()
It works fine.
But after about 1000 loops I get the following messsage.
WARNING: opencell opening temp null file: no temp files available
Does anyone know what it means. I have enough space left in my ./tmp folder. And I also have write permissions on it.
Thanks in advance.
Andi
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
and the function
G_close_cell()
It works fine.
It probably means that files aren't getting closed, so you are
exceeding the limit on the number of open files per process (by
default 1024, check with ulimit -n).
On Linux, you can check which files a process has open by looking in
the /proc/<pid>/fd directory, where <pid> is the PID of the process.
If you're modifying a map "in-place", you'll need to close and re-open
the input map in order to see the changes. Opening a map for write
creates a temporary file, which is renamed over the original when
closed. If the original cell/fcell file is still open for read at that
point, it will still exist and still be open (it will show up as
"(deleted)" in /proc/<pid>/fd).
