[GRASS-dev] ParallelModuleQueue freezes...
Dear devs,
Currently, I am trying to run a combination of ParallelModuleQueue and MultiModule as described here in GRASS 7.8:
https://grass.osgeo.org/grass79/manuals/libpython/pygrass.modules.interface.html?highlight=parallel%20module%20qu#pygrass.modules.interface.module.ParallelModuleQueue
It seems – in contrast to the documentation - also the finish_= parameter needs to be set to True for the modules to run.
However, after finishing the queue, the script stalls and does not seem to get over queue.wait().
Just to be clear, also the code from the doc does not seem to work for me…
Any ideas?
Stefan
Hi Stefan,
On Tue, May 25, 2021 at 2:33 PM Stefan Blumentrath
<Stefan.Blumentrath@nina.no> wrote:
Dear devs,
While I have no direct recommendation you may want to check the
working code here, in the addons:
- t.rast.mosaic
- t.sentinel.import
- t.sentinel.mask
- t.rast.resample
See: https://github.com/search?q=org%3Amundialis+ParallelModuleQueue&type=code
Best,
Thanks, Markus.
Seems that the ParallelModuleQueue itself works if it is fed with Module objects, but not if MultiModule objects are put into the queue...
So, I believe I am struggling with the same issue as Luca:
https://github.com/OSGeo/grass-addons/pull/523#issue-629160914
Can it be that returns of the MuliModule should be different? If I understand the source code [1] correctly, Module returns "self" (a Module object) while MultiModule returns "None". Can that be the root cause?
Any help is much appreciated...
Stefan
1: https://grass.osgeo.org/grass79/manuals/libpython/_modules/pygrass/modules/interface/module.html#MultiModule
-----Original Message-----
Sent: tirsdag 25. mai 2021 20:17
To: Stefan Blumentrath <Stefan.Blumentrath@nina.no>
Cc: GRASS developers list <grass-dev@lists.osgeo.org>
Subject: Re: [GRASS-dev] ParallelModuleQueue freezes...
Hi Stefan,
On Tue, May 25, 2021 at 2:33 PM Stefan Blumentrath <Stefan.Blumentrath@nina.no> wrote:
Dear devs,
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgras
s.osgeo.org%2Fgrass79%2Fmanuals%2Flibpython%2Fpygrass.modules.interfac
e.html%3Fhighlight%3Dparallel%2520module%2520qu%23pygrass.modules.inte
rface.module.ParallelModuleQueue&amp;data=04%7C01%7C%7C61c3f8df57d44d9
0905108d91fa9435d%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C6375756
34109191335%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMz
IiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&amp;sdata=PC64zLohfEqbxUcNfX4U
hHHNf5VIgRO7x0o%2FbiYHyU4%3D&amp;reserved=0
It seems - in contrast to the documentation - also the finish_= parameter needs to be set to True for the modules to run.
me...
While I have no direct recommendation you may want to check the working code here, in the addons:
- t.rast.mosaic
- t.sentinel.import
- t.sentinel.mask
- t.rast.resample
See: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fsearch%3Fq%3Dorg%253Amundialis%2BParallelModuleQueue%26type%3Dcode&amp;data=04|01||61c3f8df57d44d90905108d91fa9435d|6cef373021314901831055b3abf02c73|0|0|637575634109191335|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=tbzIS%2FhRmi6hWOAuieoNxubEN73Q8MDmfqHK0wyy7eE%3D&amp;reserved=0
Best,
On Wed, 26 May 2021 at 15:13, Stefan Blumentrath
Thanks, Markus.
probably yes
it seems to me that MultiModule returns "None" when it finish
otherwise return self.p (a Process instance)
same for my side :slight_smile:
Stefan
ciao
Luca
www.lucadelu.org
Could you provide an example that is failing? The doctests are running for me. I spent some time fixing it a couple months ago. I use Python 3.6, I wonder if newer Python would cause some issues.
Anna
On Tue, May 25, 2021 at 8:33 AM Stefan Blumentrath <Stefan.Blumentrath@nina.no> wrote:
Dear devs,
Any ideas?
Stefan
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
https://github.com/OSGeo/grass-addons/pull/523/files line 544, the
commented lines are not working for me..
If you want to try t.vi just comment line 543 and uncomment the
following lines..
Anna
ciao
Luca
www.lucadelu.org
The combination ParallelModuleQueue and MultiModule is used in t.rast.neighbors: https://github.com/OSGeo/grass/blob/master/temporal/t.rast.neighbors/t.rast.neighbors.py
The testsuite of that module is deactivated for Python > 2.
https://github.com/OSGeo/grass/blob/master/temporal/t.rast.neighbors/testsuite/test_neighbors.py
If you activate it by commenting out line 15. You will see the behavior...
Thanks for looking into this!
Stefan
Sent: torsdag 27. mai 2021 06:07
To: Anna Petrášová <kratochanna@gmail.com>
Cc: Stefan Blumentrath <Stefan.Blumentrath@nina.no>; GRASS developers list <grass-dev@lists.osgeo.org>
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass-addons%2Fpull%2F523%2Ffiles&amp;data=04|01||b35d171402fc441dfd7508d920c4edc3|6cef373021314901831055b3abf02c73|0|0|637576852445926368|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=a8JVAn3N77HwODX5FguDQjxI4PbUbkN4ZicO4RYuHqo%3D&amp;reserved=0 line 544, the commented lines are not working for me..
If you want to try t.vi just comment line 543 and uncomment the following lines..
Anna
ciao
Luca
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.lucadelu.org%2F&amp;data=04|01||b35d171402fc441dfd7508d920c4edc3|6cef373021314901831055b3abf02c73|0|0|637576852445936369|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=RWkoI4e%2BbY9%2F5Ow%2BOMqPtEgHGS2BqWRL4pes%2B%2B5T%2BNA%3D&amp;reserved=0
See:
https://github.com/OSGeo/grass/pull/1600
Please test.
Unittests for t.rast.neighbors should work again with this small change...
From: grass-dev <grass-dev-bounces@lists.osgeo.org> On Behalf Of Stefan Blumentrath
Sent: torsdag 27. mai 2021 08:19
To: Luca Delucchi <lucadeluge@gmail.com>; Anna Petrášová <kratochanna@gmail.com>
The combination ParallelModuleQueue and MultiModule is used in t.rast.neighbors: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass%2Fblob%2Fmaster%2Ftemporal%2Ft.rast.neighbors%2Ft.rast.neighbors.py&amp;data=04|01||9ed002957eca4be47b7908d920d75b53|6cef373021314901831055b3abf02c73|0|0|637576931588309077|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=2zjyEI5TAne19FgKv9vZo%2FcNG1SGP0KP7u0G%2FtQdC5Q%3D&amp;reserved=0
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass%2Fblob%2Fmaster%2Ftemporal%2Ft.rast.neighbors%2Ftestsuite%2Ftest_neighbors.py&amp;data=04|01||9ed002957eca4be47b7908d920d75b53|6cef373021314901831055b3abf02c73|0|0|637576931588319065|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=jHctgXkjIEHaZ%2BHveeBo49RnOvzzB%2BRhWq7ri2PY59g%3D&amp;reserved=0
Stefan
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass-addons%2Fpull%2F523%2Ffiles&amp;data=04|01||9ed002957eca4be47b7908d920d75b53|6cef373021314901831055b3abf02c73|0|0|637576931588319065|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=e9%2FkUD2TLUp2AHji07wI56Q0pkF%2Bctld3qtTnsb9%2F34%3D&amp;reserved=0 line 544, the commented lines are not working for me..
Anna
ciao
Luca
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.lucadelu.org%2F&amp;data=04|01||9ed002957eca4be47b7908d920d75b53|6cef373021314901831055b3abf02c73|0|0|637576931588319065|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=tgQKu%2BWrWIu2PDesyTQ41Hk%2Bp%2FOdeU3itdIrluTwwBA%3D&amp;reserved=0
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-dev&amp;data=04|01||9ed002957eca4be47b7908d920d75b53|6cef373021314901831055b3abf02c73|0|0|637576931588319065|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=mN%2FeOFVJIQ8PZ2P6GEGM903s44%2BHbcGpodK4yxPxwY4%3D&amp;reserved=0
Some more context.
The t.rast.neighbors test seems to work with the current dev version
"2048e1016" from 2021-05-19T09:38:49+00:00
It fails however, with 7.8.5 from 2020-12-22T15:55:09+00:00 and an older development version "35edbf7dc"
from 2020-06-03T16:03:52+00:00
So, maybe one or more of the recent changes need backporting?
https://github.com/OSGeo/grass/commits/master/python/grass/pygrass/modules/interface/module.py
In the 7_8 release branch, the latest change is from May 2019:
https://github.com/OSGeo/grass/commits/releasebranch_7_8/lib/python/pygrass/modules/interface/module.py
Hope that helps identifying a solution?
Stefan
From: Stefan Blumentrath <Stefan.Blumentrath@nina.no>
Sent: torsdag 27. mai 2021 23:09
To: Stefan Blumentrath <Stefan.Blumentrath@nina.no>; Luca Delucchi <lucadeluge@gmail.com>; Anna Petrášová <kratochanna@gmail.com>
Subject: RE: [GRASS-dev] ParallelModuleQueue freezes...
See:
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass%2Fpull%2F1600&amp;data=04|01||c5fe909715a647431c9308d92153b445|6cef373021314901831055b3abf02c73|0|0|637577465653048701|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=5yfxG5gjlYlzgJn6yTP9zbUk7GE1JdcYPxWIQFwUK%2Fo%3D&amp;reserved=0
Please test.
The combination ParallelModuleQueue and MultiModule is used in t.rast.neighbors: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass%2Fblob%2Fmaster%2Ftemporal%2Ft.rast.neighbors%2Ft.rast.neighbors.py&amp;data=04|01||c5fe909715a647431c9308d92153b445|6cef373021314901831055b3abf02c73|0|0|637577465653048701|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=5QyN%2FR1cXgoWWGS2lgjKi8%2BeLX77w37bfMQzcP6O4bM%3D&amp;reserved=0
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass%2Fblob%2Fmaster%2Ftemporal%2Ft.rast.neighbors%2Ftestsuite%2Ftest_neighbors.py&amp;data=04|01||c5fe909715a647431c9308d92153b445|6cef373021314901831055b3abf02c73|0|0|637577465653048701|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=nQTdDIGmefI6F37zdjhyMDBYUrIxVaC%2FiA5FzeUK2KU%3D&amp;reserved=0
Stefan
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass-addons%2Fpull%2F523%2Ffiles&amp;data=04|01||c5fe909715a647431c9308d92153b445|6cef373021314901831055b3abf02c73|0|0|637577465653048701|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=KT5h55J89LLXhK7uEujAmIwfksjPGyXEy2u7gYIc2Ns%3D&amp;reserved=0 line 544, the commented lines are not working for me..
Anna
ciao
Luca
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.lucadelu.org%2F&amp;data=04|01||c5fe909715a647431c9308d92153b445|6cef373021314901831055b3abf02c73|0|0|637577465653048701|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=hM8CpSgjw7SFjGKxM9SFfWI3G8U3nr8eeCqedZORdso%3D&amp;reserved=0
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-dev&amp;data=04|01||c5fe909715a647431c9308d92153b445|6cef373021314901831055b3abf02c73|0|0|637577465653048701|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=IwP5QxiLzELTGrr393lqAWrlWRhBVg%2FbOhrz9lBHMkw%3D&amp;reserved=0
Which Python do you have? The test is running just fine for me with 3.6.
On Thu, May 27, 2021 at 2:19 AM Stefan Blumentrath <Stefan.Blumentrath@nina.no> wrote:
If you activate it by commenting out line 15. You will see the behavior…
Stefan
Subject: Re: [GRASS-dev] ParallelModuleQueue freezes…
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass-addons%2Fpull%2F523%2Ffiles&data=04%7C01%7C%7Cb35d171402fc441dfd7508d920c4edc3%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637576852445926368%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=a8JVAn3N77HwODX5FguDQjxI4PbUbkN4ZicO4RYuHqo%3D&reserved=0 line 544, the commented lines are not working for me…
If you want to try t.vi just comment line 543 and uncomment the following lines…
Anna
ciao
Luca
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.lucadelu.org%2F&data=04%7C01%7C%7Cb35d171402fc441dfd7508d920c4edc3%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637576852445936369%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=RWkoI4e%2BbY9%2F5Ow%2BOMqPtEgHGS2BqWRL4pes%2B%2B5T%2BNA%3D&reserved=0
On Fri, May 28, 2021 at 10:02 AM Stefan Blumentrath <Stefan.Blumentrath@nina.no> wrote:
Some more context.
“2048e1016” from 2021-05-19T09:38:49+00:00
It fails however, with 7.8.5 from 2020-12-22T15:55:09+00:00 and an older development version “35edbf7dc”
This one:
https://github.com/OSGeo/grass/pull/1407
The reason I didn’t backport it was there has been a small change in API to make it work. But Python3 support is probably a good reason to backport it.
Stefan
Subject: RE: [GRASS-dev] ParallelModuleQueue freezes…
See:
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass%2Fpull%2F1600&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=5yfxG5gjlYlzgJn6yTP9zbUk7GE1JdcYPxWIQFwUK%2Fo%3D&reserved=0
Please test.
Unittests for t.rast.neighbors should work again with this small change…
The combination ParallelModuleQueue and MultiModule is used in t.rast.neighbors: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass%2Fblob%2Fmaster%2Ftemporal%2Ft.rast.neighbors%2Ft.rast.neighbors.py&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=5QyN%2FR1cXgoWWGS2lgjKi8%2BeLX77w37bfMQzcP6O4bM%3D&reserved=0
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass%2Fblob%2Fmaster%2Ftemporal%2Ft.rast.neighbors%2Ftestsuite%2Ftest_neighbors.py&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=nQTdDIGmefI6F37zdjhyMDBYUrIxVaC%2FiA5FzeUK2KU%3D&reserved=0
Stefan
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass-addons%2Fpull%2F523%2Ffiles&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=KT5h55J89LLXhK7uEujAmIwfksjPGyXEy2u7gYIc2Ns%3D&reserved=0 line 544, the commented lines are not working for me…
Anna
ciao
Luca
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.lucadelu.org%2F&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=hM8CpSgjw7SFjGKxM9SFfWI3G8U3nr8eeCqedZORdso%3D&reserved=0
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-dev&data=04%7C01%7C%7Cc5fe909715a647431c9308d92153b445%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637577465653048701%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=IwP5QxiLzELTGrr393lqAWrlWRhBVg%2FbOhrz9lBHMkw%3D&reserved=0
Hi Anna,
Thanks for clarification.
Would be great if you could backport #1407. I don`t know if the PR depends on others…
But if it is safe to backport just this one, I could do that too of course.
In core, MultiModule is used just in t.rast.neighbors, it seems. And that module thus does not work in GRASS 7.8 right now. So the current state can be considered a bug…
Would be great if it would be possible to get that into 7.8.6 somehow, even if there is already a RC. I am about to finish a new AddOn, where I would like to use the combination of MultiModule and ParallelModuleQueue. The development version of GRASS will not be available in the production environment in my institute for quite some time, so I would have to wait for some month to use the addon…
Stefan
Sent: fredag 28. mai 2021 16:36
To: Stefan Blumentrath Stefan.Blumentrath@nina.no
Cc: Luca Delucchi lucadeluge@gmail.com; GRASS developers list grass-dev@lists.osgeo.org
Some more context.
This one:
Stefan
See:
Please test.
Stefan
Anna
ciao
Luca
