[GRASS-dev] Passed: GRASS-GIS/grass-ci#1695 (master - 4a2caea)
Build #1695 passed.
13 minutes and 59 seconds
Markus Neteler
4a2caea Changeset →
r.in.wms manual: new example with Topographic WMS with OpenStreetMap
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@69842 15284696-431f-4ddb-bdfa-cd5b030d7da7
System message:
sudo apt-get update fails on sudo enabled Trusty builds. We’re currently working on a hotfix, check this for more details and a workaround. Thank you
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
