[GRASS-dev] patch for grass_trunk d.vect.thematic
Hello,
A little patch for d.vect.thematic.py in trunk. It shows up if you use
  d.vect.thematic themetype=graduated_points
It fixes 2 things. An unquoted string "graduated_lines". f_psmap not
being initialized although it is used line 1049. I moved the f_psmap
initialization before.
Pat
(attachments)
d.vect.thematic_init_f_psmap_quote_graduated_lines.diff (1.08 KB)
On 30/01/12 23:10, Patrice Dumas wrote:
Hello,
Thanks, I'll apply it in SVN.
Moritz
Hello,
Done.
Moritz
>>Hello,
Done.
Thanks !
Pat
