On Wed, Apr 23, 2008 at 8:14 AM, Hamish <hamish_b@yahoo.com> wrote:
Markus Neteler wrote:
> I wonder if I could colorize the 3D TIN somehow using v.colors.
> So far it does not have a DB connected.
create a DB table for it with columns="int cat, GRASSRGB varchar(11)" and
v.db.addtable tin col="east double precision, north double precision, \
height double precision, GRASSRGB varchar(11)"
[... not needed ... ]
somehow for each triangle extract the 3 elev values (v.extract +
v.out.ascii in a loop would work but probably there is a better way,
maybe v.to.db or like v.what.vect). do either SQL magic or awk magic or
..?. to get an average value for the triangle
That's now automatically done with the recent 3D extentions to v.delaunay
(the Vect_tin_get_z() was sleeping for some years, now used).
upload the mean to the centroid with v.db.update or similar, then run
v.colors..
# transfer geometry for colorizing
v.to.db tin opt=coor col="east,north,height"
v.db.select tin
v.colors tin column=height rgb_column=GRASSRGB color=rainbow
Should work... but it fails due to a precision problem in the output
of v.db.select:
Looking up colors ...
+ v.db.select map=tin layer=1 column=height
+ sort -n
+ grep '^[-0-9]'
+ uniq
+ r.what.color -i in=tmp_colr_22337
+ sed -e 's/: /|/'
+ grep -v '|\*$'
+ read LINE
++ echo '1.353553|255:255:0'
++ cut -f1 '-d|'
+ VALUE=1.353553
++ cut -f2 '-d|'
+ COLR=255:255:0
+ echo 'UPDATE tin SET GRASSRGB = '\''255:255:0'\'' WHERE height = 1.353553;'
[ for comparison:
v.db.select output:
D3/3: fetch row = 4
D3/3: col 0, litetype 2, sqltype 6: val = '4.0'
D3/3: Row fetched
4
D3/3: fetch row = 5
D3/3: col 0, litetype 2, sqltype 6: val = '2.35355339059327'
D3/3: Row fetched
2.353553
sqlite3 /home/neteler/grassdata/eth_utm32/PERMANENT/sqlite.db
SQLite version 3.4.2
Enter ".help" for instructions
sqlite> select * from tin;
1|3.53553390593274|6.46446609406726|1.35355339059327|
2|6.46446609406726|3.53553390593274|1.35355339059327|
3|13.5355339059327|6.46446609406726|2.64644660940673|
4|6.46446609406726|13.5355339059327|2.64644660940673|
5|16.4644660940673|3.53553390593274|2.06066017177982|
6|16.4644660940673|13.5355339059327|4.0|255:0:1
7|3.53553390593274|16.4644660940673|2.35355339059327|
8|13.5355339059327|16.4644660940673|4.0|255:0:1
sqlite>
Should we fix the v.db.select output (new flag for full precision output)?
