[GRASS-dev] Plan to build Package to use GRASS from R
On Wed, Jul 2, 2008 at 4:30 PM, Paul Kelly
<paul-grass@stjohnspoint.co.uk> wrote:
On Wed, 2 Jul 2008, Rainer M Krug wrote:
I finally started working on the implementation of grass commands from
R and most of the translation from the the output from
--interface-description is working. I just have one question at the
moment: some flags require "--" and others "-" and I could not fiind
any indication in the
--interface-description output which one uses which.
Any ideas where I can get that info from?
Flags that are interpreted by the GRASS module option parser and have a
common meaning to all modules are prefixed by --. There is a fixed number of
these (see lib/gis/parser.c for details). The interpretation of flags with a
single - is defined by individual modules when they call G_parser() and the
meaning of single - flags is individually dependent on each module.
Thanks - that explains.I already expected something along these lines.
Is there a way to retrieve these parameter or do I have to hardcode
them (which I would not like to do)?
I wonder if the special parser flags should be left out of the
--interface-description output. Certainly they should be given a different
name to distinguish them from the individual module flags - it's very
confusing the way it is at the minute.
Yes - at least from my perspective. The other option would be to name
them differently - e.g. comflags for common flags?
Paul
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Plant Conservation Unit
Department of Botany
University of Cape Town
Rondebosch 7701
South Africa
Paul:
parser and have a common meaning to all modules are prefixed
by --. There is a fixed number of these (see lib/gis/parser.c
for details). The interpretation of flags with a single - is
and the meaning of single - flags is individually dependent
on each module.
see http://grass.osgeo.org/wiki/Module_command_line_parser
the --interface-description output.
note that --overwrite comes and goes depending of if it is relevant
to the module.
re. the module list of flag from r.buffer --help: the vertical descriptions
of flags uses the short version (--q), but note that the top USAGE: line
has the long version. Both ways are listed there on purpose as a hint.
Hamish
On Wed, Jul 2, 2008 at 4:45 PM, Hamish <hamish_b@yahoo.com> wrote:
Paul:
on each module.
Thanks - so I will hardcode them at the moment following that description.
to the module.
Hamish
Rondebosch 7701
South Africa
