Sorry for crossposting, but I think this can be of interest for GRASS
and
R
users.
I am planning to write a package to make the use of GRASS from R
easier.
The
idea is to wrap the system call to execute the GRASS command into an
R
command of the same name.
e.g:
r.to.vect <- function(..., intern=TRUE, ignore.stderr=FALSE)
comm <- paste( "r.to.vect ", ..., sep="" )
print(comm)
system( comm, intern=intern, ignore.stderr=ignore.stderr )
My questions are:
1) Is this a good way of doing it, or is giving a named list to the
function
more usefull?
If R provides a way to pass individual arguments (argc/argv), use that
instead of contructing a shell command as a string. Otherwise, you are
likely to run into problems with shell metacharacters in argument
values.
(Replying in Nabble because Rainer's posting has been swallowed by
threading everywhere else)
This is the key sympton, seen recently in a similar interface to SAGA,
where the package author carelessly converted all "/" to "\" (it is
only
on Windows), thus destroying a valid r.mapcalc-like operation.
It is made worse by differences between Unixen and Windows in handling
stdout and stderr, and by differences between CygWin and MSYS in what
the
GRASS commands are called in system() - MSYS wants an *.exe.
R has a mechanism to detect the OS and, and that could be used to deal
with
"/" or "\" issues as well as other differences (one thing I haven't
considered yet as) .
One way of dealing with the different OS concerning stderr and stdout
would
be using the command system() in R as it already adresses these issues
(as
far as I know) and I managed to write usable wrappers around a few of
the
grass commands, including r.mapcalc. But especially r.mapcalc required
manual tweaking...
It is precisely manual tweaking that gets broken ...
That's why I would like to avoid it...
2) Is there a way to obtain easily all commands from GRASS and the
parameters possible and required?
You can obtain a list of commands by enumerating the $GISBASE/bin and
$GISBASE/scripts directories. Nearly all commands support the
--interface-description switch, which outputs details of all of the
options in XML. There are several other switches which output the same
information in different formats; see the g.parser manpage for
details.
Actually, the interface problem for R is almost exactly the same as
for
all the other front ends - think of R as a CLI-UI. Using XML in R to
set
up commands going from R to GRASS might not be impossible, where there
would be only one command - do_GRASS(), taking the GRASS command as
its
required argument, and relying on the GRASS GUI to put up a dialogue.
If
there were further arguments, then they would be used in the context
of
the requested command.
That sounds like a good approach and as a starting point - as ultimately
I
would like to be able to call e.g. r.in.bin() from R instead of
do_GRASS("
r.in.bin", ...). I am using R a lot at the moment to write ecological
simulation models, and to use the commands directly makes the programs
much
more readable as emacs highlights the commands. I will look into xml
parsers
under R to geth the information out of the grass command.
The workhorse has to be a do_GRASS() talking to GRASS in a standardised
way (mirroring g.parser?). Whether you then generate aliases for it taking
the names of the first argument is a detail, but not a trivial one. You
will certainly need a NAMESPACE in R, and do_GRASS() will be several
orders of magnitude easier to debug.
I agree completely. But for readability, I would still like to have these
wrappsers. But One could leave them for a later stage and to get do_GRASS()
working.
The GRASS command names are not
guaranteed to be unique seen from the R side - load a contributed package
into the R workspace with its own g.list(), say, and which one will you
get?
Isn't that a general problem with using packages? There are several packages
which overwrite other functions in other packages and they give a warning
message when loading.
But the others *are* still available through namespaces, if the contributed package author used a NAMESPACE.
But it would be nice to avoid these conflicts - one
could introduce these wrappers as g.list.GRASS().
As an emacs user, I would actually prefer using do.GRASS() instead of
do_GRASS() - but that is a minor point. As far as I know, there are no
conventions in R concerning this?
Please note that generic methods dispatch on the .* of names for S3 (old-style) classes. I don't think that "GRASS" is used as an S3 class name, but if it was, you'd get badly hurt by that. You need to look at the class/method system too.
For example, summary.lm() is a different method from summary.default(), and both are used as summary() dispatching on the class of the first argument. I used to use "." in function names but now largely avoid it for this reason. do.GRASS would be a "do" method for an object of S3 class "GRASS". Visual editor concerns are minor by comparison. This will also (as you can see) impact the use of regular GRASS command names as R functions.
Roger
Rainer
Roger
I haven't been following the GUI discussion, so wonder whether the
--interface-description output is cached anywhere? If not, do_GRASS()
would retrieve that first, and then try to insert given arguments,
using
platform specific "glue" to move forward. Has the (excellent, by the
way)
progress on GUI provided a way of passing a "bubble" (say in XML) to
commands, to avoid having to step around shell metacharacters? The
same
for error handling? It feels as though g.parser will help a lot.
If the grass commands are created automatically and included into a
package
(in addition to the flexible do_GRASS()), this would not be that
relevant,
as the creation of the code only happens once (either at coding time of
the
package or at compilation time - that would make the system much more
flexible as only GRASS commands / scripts installed be available).
Rainer
Roger
grass-dev mailing list
grass-dev@lists.osgeo.org
View this message in context:
http://www.nabble.com/Plan-to-build-Package-to-use-GRASS-from-R-tp15712877p15731306.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand@nhh.no
Roger Bivand
