I´ve tried many times and from different mirrors to install Wingrass native on my computer (I have a Windows XP system) but the integrity check failed, there is the possibility to have a copy of Wingrass to install it?
thank you
simone
thank you
simone
Ciao Simone,
it’s really strange! do you use a download manager? if yes, disable it and download it again.
Grab the self installer from here: http://grass.osgeo.org/grass63/binary/mswindows/native/WinGRASS-6.3.0-3-Setup.exe
I just downloaded and tested it, and it works fine.
Marco
----- Original Message -----
To: grass-dev@lists.osgeo.org
Sent: Tuesday, June 24, 2008 2:19 PM
Subject: [GRASS-dev] Problem with wingrassI´ve tried many times and from different mirrors to install Wingrass native on my computer (I have a Windows XP system) but the integrity check failed, there is the possibility to have a copy of Wingrass to install it?
thank you
simone
grass-dev mailing list
hello,
i have just downloaded and installed the file without any problem.
the checksum for it below.
# MD5 checksums generated by MD5summer (http://www.md5summer.org)
# Generated 6/24/2008 2:56:22 PM
*WinGRASS-6.3.0-3-Setup.exe
c61f821ebd1d8033e2939268efc92d03
bye
Marco
2008/6/24, Marco Pasetti <marco.pasetti@alice.it>:
Ciao Simone,
it's really strange! do you use a download manager? if yes, disable it and
download it again.
I just downloaded and tested it, and it works fine.Marco
there is the possibility to have a copy of Wingrass to install it?thank you
simone
http://lists.osgeo.org/mailman/listinfo/grass-dev_______________________________________________
