[GRASS-dev] Problems with r.out.gdal byte export: colors modified in RGB multilayer GeoTIFF
I am currently processing satellite data > 8bit and created a nice
"natural color" RGB composite (channels separated).
Using the #map operator of r.mapcalc I could successfully reduce each
channel to 8 bit, after i.colors.enhance the respective RGB composite
looks almost identical.
The scope is to process the data in GRASS GIS, then export them for a
performant OGC Web service.
So far so nice. Now, exporting it as a multilayer GeoTIFF (I made a
group of the 3 channels using i.group, then gave that as input to
r.out.gdal) leads to yellowish colors which are not the same any more.
Adding the -c flag did not help.
GRASS 7.1.svn (utm48n): > r.out.gdal -c input=rgb_group
output=rgb_8bit_flag_c.tif
Checking GDAL data type and nodata value...
100%
Using GDAL data type <Byte>
100%
100%
Exporting raster data to GTiff format...
100%
100%
100%
r.out.gdal complete. File <rgb_8bit_flag_c.tif> created.
[Raster MASK present]
Screenshot attached (top left: original; top right: reduced to 8 bit;
low: exported multilayer-RGB shown in QGIS).
I also tried the HFA driver, same issue.
What's the trick?
thanks
(attachments)
I recently experienced some buggy image color table management by Qgis,
did not dig much deeper. Sorry if my case may be the exact inverse of
yours, but I finally did it to obtain a more "faithful" color rendering:
- composited an initial 3-band image
  r.composite [...]
- then exported it with
  r.out.gdal [...] format=GTiff type=UInt16
- and expanded it again to a 3-band rgb image via :
  gdal_translate -expand rgb [...]
Anyway, since Qgis Lyon, we have some trouble wih image color
management.
Yours,
V.
Le mercredi 10 février 2016 à 10:05 +0100, Markus Neteler a écrit :
100%
100%
100%
100%
100%
100%
What's the trick?
thanks
grass-dev mailing list
grass-dev@lists.osgeo.org
        r.composite [...]
Thanks for the tip. We tried and the colors are better but a black "no
data" area came back which I managed to remove in GRASS GIS.
How complicated :slight_smile:
management.
We checked and the yellowish white also shows up in Geoserver. So I
guess it is a GDAL/GeoTIFF issue at this point.
Perhaps worth a GDAL ticket?
Le lundi 22 février 2016 à 20:43 +0100, Markus Neteler a écrit :
but a black "no data" area came back
couldn't you have managed this issue with gdal_translate -a_nodata
option ?
V.
option ?
Unfortunately not because it will set any 0 to nodata (even in the
image, not only at the border)...
