[GRASS-dev] problems with vector file import
hi,
on grass 6.3, gdal 1.5.1 I can not import one vector file, nomatter,
if it is shapefile or GML (converted using ogr2ogr). I tested another
vector file with over 10 000 polygons, no problem
I get bunch of messeges like
WARNING: Area size [1.6e-05], area not imported
WARNING: Area size [2.5e-07], area not imported
WARNING: Area size [3.8e-05], area not imported
WARNING: Area size [3.0e-05], area not imported
WARNING: Area size [9.0e-06], area not imported
WARNING: Area size [1.5e-05], area not imported
WARNING: Area size [5.1e-06], area not imported
WARNING: Area size [6.2e-06], area not imported
WARNING: Area size [8.6e-05], area not imported
and at the end, only four polygons are created (out of cca 60).
if I do display the file in qgis, everything looks all right
sample file can be downloaded from
(GML) http://les-ejk.cz/tmp/pole2009.gml
(SHP) http://les-ejk.cz/tmp/pole2009.tgz
what should I do?
thanks
jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Jachym Cepicky:
nomatter, if it is shapefile or GML (converted using ogr2ogr).
I tested another vector file with over 10 000 polygons, no problem
v.in.ogr --help:
  min_area Minimum size of area to be imported (square units)
              Smaller areas and islands are ignored. Should be
              greater than snap^2
             default: 0.0001
adjust that option as needed.
"ERROR 503: Service Unavailable."
Hamish
