[GRASS-dev] [Projects] OSGeo Annual General Meeting - projects please join and report (August 30 2018)
Hi devs, all,
for the upcoming FOSS4G conference we shall prepare a quick (2 minute)
project update for GRASS GIS, like last year.
Who will be in Dar and willing to present our updates there?
Happy to help collecting the material. Also catchy screenshots are
always welcome!
thanks
---------- Forwarded message ----------
From: Astrid Emde (OSGeo Secretary) <secretary@osgeo.org>
Date: Thu, Aug 2, 2018 at 10:13 PM
Subject: [Projects] OSGeo Annual General Meeting - projects please
To: Projects <projects@lists.osgeo.org>
Dear OSGeo projects & project officers,
the OSGeo Annual General Meeting (AGM) is scheduled for Thursday
morning August 30 at 8:00-9:00 in Dar Es Salaam (Tansania).
As Project/Committee officer we ask that you attend, or send a
delegate from your community. The FOSS4G organizers have given us one
hour for the meeting, leaving us each with around 2 mins!
This update is about your project and community, rather than about
your software. We are interested in how your community is doing, the
opportunities and challenges ahead, and how OSGeo can help.
The shared slide deck is available here (request edit access if required):
* https://docs.google.com/presentation/d/1imiG7x09ry7lGvmS15FCVq2Z7yaICY00fcpXBK27TXY/edit?usp=sharing
These slides replace the "Annual General Report"
(https://github.com/geotools/geotools/wiki/GeoTools-Annual-Report-2017)
used previously, you may wish to borrow that format for inspiration.
You still can make an annual report page with extended information if
you like and link to it.
If you are unable to attend we ask that you submit an annual general
report to the board email list and attend an IRC board meeting by
November 2018.
We are coordinating activities on the OSGeo Wiki
(https://wiki.osgeo.org/wiki/Annual_General_Meeting_2018). Please add
your project and name to the wiki if you can attend.
Best regards
Astrid Emde
OSGeo Board Member and OSGeo Secretary
Open Source Geospatial Foundation
https://www.osgeo.org/member/astrid-emde/
astrid_emde@osgeo.org
Projects mailing list
Projects@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/projects
On 3 August 2018 at 15:48, Markus Neteler <neteler@osgeo.org> wrote:
Hi devs, all,
I will be there and available.
always welcome!
yes please, I have few time to work on it...
thanks
ciao
Luca
www.lucadelu.org
Items for the presentation can be collected (and preserved!) at the following wiki page which I created based on the description for the slides.
https://trac.osgeo.org/grass/wiki/AnnualReports/2018
Here is what we showed in 2017 (slides 33 & 34):
https://docs.google.com/presentation/d/1T9QRcCdyd8PLQnXB2VfZ2k3ReX-9CH_YXRg0VKqtgeQ/edit?usp=sharing
I have created a page for 2017 based on the two slides from AGM 2017:
https://trac.osgeo.org/grass/wiki/AnnualReport/2017
The page for 2018 is here (please, contribute):
https://trac.osgeo.org/grass/wiki/AnnualReport/2018
I just uploaded my first GRASS GIS addon r.in.pdal:
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.in.pdal.
Best regards,
Anika
Anika Bettge
- Anwendungsentwicklerin -
mundialis GmbH & Co. KG
Kölnstraße 99
53111 Bonn
Tel: +49 (0)228 / 38 75 80 -80
Fax: +49 (0)228 / 96 28 99 -57
Email: bettge@mundialis.de
Web: https://www.mundialis.de
Amtsgericht Bonn, HRA 8528
Komplementärin: mundialis Verwaltungsgesellschaft mbH
vertreten durch: Dr. Markus Neteler, Hinrich Paulsen, Till Adams
Informationen über Ihre gespeicherten Daten finden Sie auf unserer Homepage unter folgendem Link:
https://www.mundialis.de/datenschutzerklaerung
2018-08-06 12:12 GMT+02:00 Anika Bettge <bettge@mundialis.de>:
Thanks a lot to your contribution Anika!
A few cosmetic suggestions:
the print command in L268 should be replaced with grass.message because this is not shell-style output
L353:
grass.message(_(“Generating output raster map <%s>…”) % outfile)
seems to be at the wrong place because nothing happens after that message
same for L191
you can you set the metadata on the resultant output raster with r.support, otherwise metadata will be set by r.in.xyz (the module that actually created the raster)
there are some comments on gdalwarp, but gdalwarp is not used by r.in.pdal
Best,
Markus M
Best regards,
Anika
Anika Bettge
  • Anwendungsentwicklerin -
Kölnstraße 99
53111 Bonn
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Hi Anika,
I’m glad to finally see this module; now I’m testing it. Please review the code and the submission guidelines. Basically it boils down to “use pep8 tool.” See the following for details.
https://trac.osgeo.org/grass/wiki/Submitting/Python#Style
To improve it even more, you can use lower_case_with_underscores (aka snake_case) instead of CamelCase/camelCase for variables and functions.
Thank you,
Vaclav
On Mon, Aug 6, 2018 at 6:50 AM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
L353:
same for L191
Best,
Markus M
Best regards,
Anika
Anika Bettge
Kölnstraße 99
53111 Bonn
I’m putting the conversation back on mailing, I hope that alright.
Hi Vaclav,
I used the pep8 tool. I get two different informations:
  1. E265 block comment should start with '# ’
    when I use ‘# %’ instead of ‘#%’ then are my parameter not valid, e.g. “FEHLER: r.in.pdal: Sorry, is not a valid parameter”
These are exception, you have to keep them as they are. See the page I linked for info on how to silence them (I usually just leave them on).
  1. E501 line too long (537 > 150 characters)
    This is in the description of the method parameter and I do not know how to write these in more than one line.
In the description that’s again a special case.
Do you know how I can solve these style problems?
If you would use some other tools than just pep8, I’m often using pylint, you will get a lot messages and you need to decide which are relevant. The main point here is to minimize them so that the code is as standardized as possible (and thus hopefully more readable).
I hope this clarifies that,
Vaclav
L353:
same for L191
Best,
Markus M
Best regards,
Anika
Anika Bettge
Kölnstraße 99
53111 Bonn
Thanks for creating the pages. I have added some content but a few
more items may be needed (and some nice screenshots)
Does anyone volunteer to update accordingly
/me at GeoSTAT 2018 at time
I asked edit access, I will do it in the next days if none will modify
it before...
ciao
Luca
www.lucadelu.org
it before…
I’ve already started the slide. Feel free to improve.
