[GRASS-dev] ps.map: how to rotate paper?
I wanted to create a landscape-A3 map but cannot figure out
how to rotate the paper (-r doesn't do what I want).
ps_info.h:#define PAGE_LANDSCAPE 2
doesn't seem to be used.
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
Add a new paper size with the width and height swapped, e.g.
    { "a3-landscape", 16.535, 11.693, 1.0, 1.0, 0.5, 0.5 },
If you want to print it, you'll need a printer which accepts
A3-landscape paper (i.e. an A2 printer).
Glynn Clements wrote on 04/27/2007 11:46 PM:
OK, done so - also for a4 (a4-landscape).
I'll use a poster print mode on a a4 printer (so that it plots on
several sheets).
