[GRASS-dev] python question
This is probably simple but I’m missing something somewhere. How can I dynamically create variable names and then assign values to the variables? I need to do something along the lines of:
for i in flist:
‘s%_new’ % i = 10
where flist is a list of strings (e.g., file names)
Thanks
Michael
C. Michael Barton
Visiting Scientist, Integrated Science Program
National Center for Atmospheric Research &
University Consortium for Atmospheric Research
303-497-2889 (voice)
Arizona State University
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
Michael Barton wrote
for i in flist:
  's%_new' % i = 10
Being not a programmer and also not sure, what you exactly want to do. But
AFAIK string replacement in Python should be coded '%s' instead of 's%'.
And '%i' is actually reserved for the replacement of integers, but you are
about to use it as an iterator as well, isn't it? Would be interesting, if
this works nevertheless ...
Regards, Christine
View this message in context: http://osgeo-org.1560.n6.nabble.com/python-question-tp4983356p4983365.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
On Sat, Jun 23, 2012 at 9:48 PM, Michael Barton <michael.barton@asu.edu> wrote:
This is probably simple but I'm missing something somewhere. How can I
for i in flist:
's%_new' % i = 10
You can find answer here:
http://stackoverflow.com/questions/2320945/python-using-vars-to-assign-a-string-to-a-variable
example of using function vars is in wxpython/gui_core/toolbars.py, line 130
Anna
Thanks
Michael
_____________________
C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
for i in flist:
  's%_new' % i = 10
You can create new global (module-scope) variables by adding them to
the dictionary returned by the globals() function.
You cannot dynamically create local variables, as the parser has to
find the variable in the function body at parse time in order for it
to be treated as a local variable. You can retrieve a dictionary of
local variables using the locals() function, but the result should not
be modified.
You can dynamically get/set object members using getattr() and
setattr().
But you should really try to avoid accessing variables dynamically, as
it makes the code harder to follow (e.g. grepping for occurrences of
"something_new" won't find the above). Wherever possible, use
dictionaries instead.
Thanks Anna and Glynn,
I got the same advice from a colleague here: use a dictionary. Works perfectly to resolve the problem.
Michael Barton
School of Human Evolution &Social Change
...Sent from my iPad
On Jun 24, 2012, at 1:56 AM, "Anna Kratochvílová" <kratochanna@gmail.com> wrote:
for i in flist:
's%_new' % i = 10
Python: Using vars() to assign a string to a variable - Stack Overflow
Anna
Thanks
Michael
C. Michael Barton
grass-dev Info Page
