[GRASS-dev] Python script problem
Hello everybody,
I'm new to python and I'm trying to build up a script...
When I run the script the only commands that are executed are
    cmdargs1= ["elevation=%s" %dtm]
    cmdargs2=["slope=slope1", "format=percent", "--overwrite"]
    os.execvp("r.slope.aspect", ["r.slope.aspect"] + cmdargs1 + cmdargs2)
The other commands are ignored...What can be the issue?
thanks,
Monia
Here is my script:
#!/usr/bin/python
# -*- coding:utf-8 -*-
#%Module
#% description:
#% keywords: keyword1, keyword2
#%End
#%option
#% key: dtm
#% type: string
#% gisprompt: old,cell,raster
#% description: Modello Digitale del Terreno
#% required : yes
#%end
#%option
#% key: h
#% type: double
#% description: Profondità del mare in prossimità della costa h
#% required : yes
#%end
#%option
#% key: ho
#% type: double
#% description: Profondità del mare in corrispondenza dell'epicentro
#% required : yes
#%end
#%option
#% key: Ho
#% type: double
#% description: Altezza d'onda nel punto di generazione dello tsunami
#% required : yes
#%end
import os,sys,subprocess,string,random,math
def main():
    #### add your code here ####
    print ""
    print "Value of GIS_OPT_h: %s" % os.getenv("GIS_OPT_h")
    print "Value of GIS_OPT_ho: %s" % os.getenv("GIS_OPT_ho")
    print "Value of GIS_OPT_Ho: %s" % os.getenv("GIS_OPT_Ho")
    print "Name of GIS_OPT_dtm: %s" % os.getenv("GIS_OPT_dtm")
    h = float(os.getenv('GIS_OPT_h'))
    ho = float(os.getenv('GIS_OPT_ho'))
    Ho = float(os.getenv('GIS_OPT_Ho'))
    dtm = os.getenv('GIS_OPT_dtm')
    Co=math.sqrt(9.8 * h)
    print "Celerità dell'onda=",Co
    H= Ho * ((ho/h)**(0.25))
    print "Altezza d'onda a riva=",H
    U=Co * math.sqrt((1+H/h))
    print "Velocità d'onda a riva=",U
    L= 4 * 2.415 *h /(math.sqrt(3*H/h))
    print "Lunghezza di un'onda solitaria=",L
    k1=U**2 * L/(19.6)
    print "k1=",k1
    k2= U**2 * H/(39.2)
    print "k2=",k2
    cmdargs3=["input=slope1", "output=slope_prova1", "method=average", "size=9"]
    os.execvp("r.neighbors",["r.neighbors"] + cmdargs3)
    #### end of your code ####
    return
if __name__ == "__main__":
    if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
        os.execvp("g.parser", [sys.argv[0]] + sys.argv)
    else:
  main();
Try the following...
"size=9"]
cmdargs1= ["r.slope.aspect","elevation=%s" %dtm,"slope=slope1",
cmdargs2=["r.neighbors", "input=slope1", "output=slope_prova1",
"method=average","size=9"]
p1 = subprocess.Popen(cmdargs1)
# NOTE: you may have to insert a wait or something here to make sure that
# slope1 is created before running the next process
p2 = subprocess.Popen(cmdargs2)
# you can do more sophisticated things with Popen if you want
# and can check return values by parsing p1 and p2
Michael
Director of Graduate Studies
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
monik1982\@libero\.it wrote:
Hello everybody,
os.execvp() doesn't return (unless it fails); it executes the
specified command *in place of* the script which calls it.
If you want to run a command without terminating the script, use
subprocess.Popen as suggested by Michael. For more details, see §17.1
of the Python library reference:
  http://docs.python.org/lib/module-subprocess.html
In most scripts, the only place where os.execvp() should be used is
for invoking g.parser.
