[GRASS-dev] question on workspace file - wxGui
Hello!
I’d like to get information in python script whether:
  • if wxGUI running or not, and if yes:
  • the name of the current workspace file, if set (opened or saved) or clearly a “no” answer if not
A multi-OS solution is welcome (linux ps filtering for wxgui works but I need something cross-platform, GRASS internal if possible)
I tried to look in sources but spent to much time and I have no idea still.
Any help is welcome.
Best regards and thanks
Robert
On Mon, Jul 11, 2016 at 9:35 AM, Robert Kuszinger <kuszinger@giscom.hu> wrote:
Hello!
I'd like to get information in python script whether:
the only thing related to that was implemented for g.gui.* modules:
https://trac.osgeo.org/grass/changeset/67232
which passes grass interface object to the main function of the
script. But this needs to be run from the GUI.
a "no" answer if not
there is information if workspace is loaded and if it has been changed
since, but it's not easily accessible, that would have to be part of
the interface. May I ask you what's your use case?
Robert
grass-dev mailing list
grass-dev@lists.osgeo.org
Anna,
thanks for the information.
Actually this is a “quick ‘n’ dirty cartography / print sheet generator”
made with the help of Vaclav in the past few weeks. It consumes workspace files for map compositions.
Presently runs on bitmap output of the cairo driver but I also dream about utf-8 postsctript
page assembly later on…
https://github.com/kuszinger/grass7/tree/master/display/d.cartosim
d.cartosim is the esperimental name, still looking for the final name of it, possibly
better in the m.* group.
My goal with workspace query would be to reach this with present nomenclature:
d.cartosim -q
-q is for quick mode where it would get the name of workspace file, if any and would
create a pdf file of A4 landscape 300dpi at the same location with the name of the workspace
file as a quick printable pdf. (current region would be used also for the visual snapshot)
I quite often need good resolution printout of my workspace (~ kind of visual map) compositions on paper
as some professors are still “offline” who I need to work with. Fast printed handouts are very useful and time saving.
Since it is for office printing, 300-600 dpi bitmap processing is enough, no need for professional postscript with stroke fonts.
So, workspace information would also be a time saver (yes, those seconds of selecting the very same workspace file with a file dialog).
Yes, I’m lazy.
best regards
Robert
2016-07-11 22:40 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
Hello!
since, but it’s not easily accessible, that would have to be part of
the interface. May I ask you what’s your use case?
Robert
On Tue, Jul 12, 2016 at 1:03 AM, Robert Kuszinger <kuszinger@giscom.hu> wrote:
Anna,
Actually this is a "quick 'n' dirty cartography / print sheet generator"
utf-8 postsctript
page assembly later on...
possibly
nomenclature:
d.cartosim -q
and would
of the workspace
visual snapshot)
as some professors are still "offline" who I need to work with. Fast printed
Yes, I'm lazy.
There could be a way to implement that, but I am not convinced it's
worth it. Basically, in the link I sent you, we wouldn't test for
scripts starting with g.gui*, but we could test also specifically for
the name of your module. Then once you get interface, you have access
to Layer Manager and its attribute workspaceFile. You can try to
implement it, but I would keep the workspace file as input for cases
when you don't run it from GUI. I guess I could commit the change into
GRASS once your module becomes more mature.
Best,
Anna
best regards
Robert
wrote:
> Hello!
> clearly
> still.
> Robert
