epy@epinux:~/dev/grass_trunk$ svn up
Updating '.':
At revision 55645.
GRASS 7.0.svn (utm19N_wgs84):~ > g.region rast=dtm1 -ap
projection: 1 (UTM)
zone: 19
datum: wgs84
ellipsoid: wgs84
north: 4720170
south: 4715050
west: 391340
east: 398580
nsres: 10
ewres: 10
rows: 512
cols: 724
cells: 370688
GRASS 7.0.svn (utm19N_wgs84):~ > r.fillnulls input=dtm1 output=dtm1 --overwrite
Using RST interpolation...
Locating and isolating NULL areas...
100%
Growing NULL areas
Assigning IDs to NULL areas
100%
Processing 1 map holes
Filling hole 2 of 1
100%
100%
100%
Note: The following warnings about number of points for interpolation may
be ignored.
ERROR: Database connection not defined for layer 1
ERROR: Failed to fill hole 2
WARNING: Raster map <r_fillnulls_5883_hole_2_dem> not found
WARNING: <r_fillnulls_5883_hole_2_dem> nothing removed
--overwrite
You try to overwrite the source with the target, to my knowledge invalid
(sure, the module should say so).
Try
r.fillnulls input=dtm1 output=dtm1_filled
I used the --overwrite option
i had problems with r.fillnulls recently see :
http://osgeo-org.1560.n6.nabble.com/r-fillnulls-error-lt-z-gt-is-not-a-valid-flag-grass7-td5034768.html
after that fix the same syntax was working
changing the output to a new name i got the same error
GRASS 7.0.svn (utm19N_wgs84):/home/epy > r.fillnulls input=dtm1 output=dtm1fill --overwrite
100%
Growing NULL areas
100%
Filling hole 2 of 1
100%
100%
100%
be ignored.
WARNING: Raster map <r_fillnulls_4517_hole_2_dem> not found
WARNING: <r_fillnulls_4517_hole_2_dem> nothing removed
Il giorno 06/apr/2013, alle ore 11:08, Markus Neteler <neteler@osgeo.org> ha scritto:
--overwrite
Try
100%
Growing NULL areas
100%
Filling hole 2 of 1
... this looks odd
100%
100%
100%
be ignored.
^^^- same problem here (I tried the example in the manual page
which fails - a bug (or two).
100%
Growing NULL areas
100%
Filling hole 2 of 1
... this looks odd
100%
100%
100%
be ignored.
Try to remove zcol = 'value' from the call to v.surf.rst in the
r.fillnulls script. The vector created by r.fillnulls with r.to.vect
is 3D, so no z column is needed (or present).
Markus M
On Sun, Apr 7, 2013 at 11:00 PM, Markus Metz
Tested, this solves the problem. I guess it is an artifact of the -z usage
in the GRASS 6 version or the r.to.vect usage.
markusN
thanks this fixed my problem!
Il giorno 07/apr/2013, alle ore 17:20, Markus Neteler <neteler@osgeo.org> ha scritto:
markusN
