Dear all,
I succesfully the module r.hazards.flood.py in windows xp but fail in windows 7.
Please help me.
Swapan Ghosh
Dear all,
Please help me.
Swapan Ghosh
Hi Swapan,
On Sun, Jul 20, 2014 at 10:47 PM, Swapan Ghosh <swap.ghsh@gmail.com> wrote:
Dear all,
how does it fail? do you get any error messages? do you have the dependencies installed (r.area) ?
which revision of grass are you using?
standalone or osgeo4w?
have you tried also running it on grass 6.4.4 and/or nightly build 7.0.0?
Please let us know.
cheers,
madi
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
SWAPAN GHOSH wrote
Dear all,
windows 7.Please help me.
Swapan Ghosh
grass-dev mailing list
grass-dev@.osgeo
please provide more information how and what fails?
did you set the region right, e.g.
g.region -p -a rast=elevation@PERMANENT align=elevation@PERMANENT
tested here with
System Info
GRASS Version: 6.4.5svn
GRASS SVN Revision: 61153
GDAL/OGR: 1.11.0
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
(Mon Jul 21 11:47:06 2014)
r.hazard.flood --verbose map=elevation@PERMANENT flood=FLOOD mti=MTI
Done.
(Mon Jul 21 11:47:25 2014) Befehl ausgeführt (18 Sek)
System Info
GRASS Version: 7.0.0svn
GRASS SVN Revision: 61281
Erstellungsdatum: 2014-07-21
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
(Mon Jul 21 11:51:42 2014)
Done.
(Mon Jul 21 11:51:57 2014) Befehl ausgeführt (15 Sek)
r.hazard.flood in winGRASS6.4.5svn and winGRASS7.0.0svn works.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-hazard-flood-is-not-running-in-windows7-Grass-6-5-tp5152002p5152074.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
Actually, it needs external python installation.
I solve it…
but my question is that…why we need external py install…other wise get the following message
Swapan Ghosh
On Mon, Jul 21, 2014 at 3:28 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
SWAPAN GHOSH wrote
Dear all,
Swapan Ghosh
grass-dev@.osgeo
tested here with
System Info
GDAL/OGR: 1.11.0
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)(Mon Jul 21 11:47:06 2014)
Done.
(Mon Jul 21 11:47:25 2014) Befehl ausgeführt (18 Sek)System Info
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)(Mon Jul 21 11:51:42 2014)
Done.
(Mon Jul 21 11:51:57 2014) Befehl ausgeführt (15 Sek)r.hazard.flood in winGRASS6.4.5svn and winGRASS7.0.0svn works.
best regards
HelmutView this message in context: http://osgeo-org.1560.x6.nabble.com/r-hazard-flood-is-not-running-in-windows7-Grass-6-5-tp5152002p5152074.html
grass-dev@lists.osgeo.org
I solve it...........
but my question is that.........why we need external py install.....other
first, please don't use winGRASS 6.5, it's some kind of abandoned and not
meant for productive use.
so try winGRASS 6.4.5svn (latest stable in the 6.4-series) or winGRASS
7.0.0svn (first stable in the 7.0-series) first before installing an
external python.
an external python isn't normally necessary, but sometimes there are some
glitches with windows and python.
AFAICT the best thing is to use winGRASS within the OSGe4W-framework
(http://trac.osgeo.org/osgeo4w/).
for example the tests mentioned before by me are done in the
OSGe4W-framework without any external python installation.
in summary this isn't a r.hazard.flood issue, but a windows-python quirk ...
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-hazard-flood-is-not-running-in-windows7-Grass-6-5-tp5152002p5152094.html
Dear all,
Thank you very much for the help.
Swapan
I solve it…
wise get the following messagefirst, please don’t use winGRASS 6.5, it’s some kind of abandoned and not
meant for productive use.so try winGRASS 6.4.5svn (latest stable in the 6.4-series) or winGRASS
external python.an external python isn’t normally necessary, but sometimes there are some
glitches with windows and python.AFAICT the best thing is to use winGRASS within the OSGe4W-framework
(http://trac.osgeo.org/osgeo4w/).for example the tests mentioned before by me are done in the
OSGe4W-framework without any external python installation.in summary this isn’t a r.hazard.flood issue, but a windows-python quirk …
best regards
HelmutView this message in context: http://osgeo-org.1560.x6.nabble.com/r-hazard-flood-is-not-running-in-windows7-Grass-6-5-tp5152002p5152094.html
