[GRASS-dev] r.median (non)functionality
Trying out r.median, I discovered
GRASS 6.3.cvs (spearfish60):~/ > r.median base=fields cover=soils.Kfactor
output=K.by.farm.median --o
100%
ERROR: Reading r.stats output
I compared to r.mode: this fix seems to be necessary:
--- main.c 15 Jul 2007 12:30:37 -0000 2.9
+++ main.c 15 Jul 2007 12:48:43 -0000
@@ -79,7 +79,7 @@
     if (G_read_cats (covermap, cover_mapset, &cover_cats) < 0)
        G_fatal_error (_("Cannot read category labels of raster map <%s>"),
covermap);
- strcpy (command, "r.stats -a \"");
+ strcpy (command, "r.stats -an \"");
     strcat (command, G_fully_qualified_name (basemap, base_mapset));
     strcat (command, ",");
     strcat (command, G_fully_qualified_name (covermap, cover_mapset));
Should I submit?
View this message in context: http://www.nabble.com/r.median-(non)functionality-tf4082074.html#a11602182
Sent from the Grass - Dev mailing list archive at Nabble.com.
100%
@@ -79,7 +79,7 @@
        G_fatal_error (_("Cannot read category labels of raster map <%s>"), covermap);
Presumably r.median fails if you have any null cells?
Should I submit?
Yes.
100%
No, it continues.
Should I submit?
Yes.
Done.
View this message in context: http://www.nabble.com/r.median-(non)functionality-tf4082074.html#a11603531
