[GRASS-dev] R.terraflow on massive grids
Hi Folks,
I have an fcell grid of elevations for the state of North Carolina (51000 rows 133000 columns 6783000000 cells) . I tried to run r.terraflow in GRASS7 ( 8/8/2011 svn snapshot) and ran into the dimension limits. So I patched them according to Glynn’s email , http://www.osgeo.org/pipermail/grass-user/2004-February/024722.html and tried again ( Would it be better to change the dimension variable to int instead of short int?) .
This time my Streams file builds to about 26 GB and then r.terraflow bombs with :
MFD flow direction
D8CUT=999999986991104.000000
Memory size: 808.00M (847249408) bytes
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
r.terraflow: grass2str.h:145: AMI_STREAM*
cell2stream(char*, elevation_type, long int*) [with T =
float, elevation_type = float]: Assertion `nrows * ncols ==
str->stream_len()’ failed.
The memory size is interesting, because I’m giving it 8GB of RAM out of 16 GB in the command. The temp directory has about 900GB of space, so it has plenty of room .
The box is 64 bit Ubuntu 11.04
related to ?
http://trac.osgeo.org/grass/ticket/1006
I can run it again in verbose mode when I get home tonight.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life is too short for undocumented, proprietary data formats.
patched them according to Glynn's email ,
I think that dimension_type has to be used consistently. There is a
class, "ijBaseType" which contains a pair of dimension_type members
(i.e. it's a coordinate pair), and there are also several classes
which derive from ijBaseType. If r.terraflow creates large arrays of
instances of ijBaseType or its subclasses, changing dimension_type to
32-bit could significantly increase memory consumption.
with :
MFD flow direction
r.terraflow: grass2str.h:145: AMI_STREAM<T>*
str->stream_len()' failed.
The memory size is interesting, because I'm giving it 8GB of RAM out of 16
plenty of room .
related to ?
Yes. The total number of cells (nrows * ncols) is too large to fit
into an "int".
In general, rasters with more than 2^31-1 cells are problematic.
Anything which counts cells risks running into similar problems.
In the case of r.terraflow, you may be able to fix this particular
issue by casting to "long" or "off_t" in the offending line, e.g.:
  assert((off_t) nrows * ncols == str->stream_len());
But there may be similar issues elsewhere in r.terraflow.
<Doug_Newcomb@fws.gov> wrote:
Hi Folks,
with :
MFD flow direction
GB in the command.
Note that the memory manager of the iostream lib used by r.terraflow
can only handle up to 2047 MB of RAM because the memory option in MB
is internally converted to Byte and stored as int, thus the max
recognized value is 2^31 - 1 Byte.
Markus M
The iostream library uses size_t. However, r.terraflow itself had a
bug (scale then cast instead of cast then scale), which should be
fixed by r47641.
Markus Metz <markus.metz.giswork@googlemail.com>
08/15/2011 06:28 AM
To
cc
grass-dev@lists.osgeo.org
Subject
Re: [GRASS-dev] R.terraflow on massive grids
>> Hi Folks,
>> ``http://www.osgeo.org/pipermail/grass-user/2004-February/024722.html and
>> with :
>> MFD flow direction
>> float, elevation_type = float]: Assertion nrows * ncols == >> str->stream_len()’ failed. >> >> The memory size is interesting, because I’m giving it 8GB of RAM out of 16 >> GB in the command.`
>Markus M
This appears to be kind of like pulling on a corner of a spiderweb. :-)
Should the limit to memory be indicated in the gui?
Would there be any benefit to other parts of GRASS in bumping up this memory limit? I can see the reason on 32 bit windows XP, but that is starting to go away.
Doug
Doug Newcomb
USFWS
Raleigh, NC
Glynn:
itself had a bug (scale then cast instead of cast then scale),
which should be fixed by r47641.
in the same class, but sort of unrelated- any thoughts on #1107?
  https://trac.osgeo.org/grass/ticket/1107
thanks,
Hamish
I'm fairly certain that it's supposed to be float and atoi() is a
typo.
Fixed in r47664.
Arbitrary 32-bit limits should ideally be fixed, but it's a game of
Whac-a-Mole. The problem usually arises as a result of using "int"
instead of long, size_t, off_t, etc.
I've fixed the original issue and one other with r47665:
--- raster/r.terraflow/grass2str.h (revision 47663)
+++ raster/r.terraflow/grass2str.h (working copy)
@@ -140,9 +140,9 @@
   /* close map files */
   Rast_close (infd);
- G_debug(3, "nrows=%d ncols=%d stream_len()=%d", nrows, ncols,
+ G_debug(3, "nrows=%d ncols=%d stream_len()=%"PRI_OFF_T, nrows, ncols,
     str->stream_len());
- assert(nrows * ncols == str->stream_len());
+ assert((off_t) nrows * ncols == str->stream_len());
   rt_stop(rt);
   stats->recordTime("reading raster map", rt);
This might cause problems on non-Linux platforms, but both r.terraflow
and LFS have always had portability issues.
