Dear devs,
i have merged the code of r.univar and r3.univar.
Please test the new modules and if no errors occure, i will replace
the current r.univar code with the new one.
The code:
http://www-pool.math.tu-berlin.de/~soeren/grass/modules/r3.univar.tar.bz2
includes r3.univar and r.univar.
Important note:
I have used a heapsort algorithm based on code from the german wikipedia:
http://de.wikipedia.org/wiki/Heapsort
The heapsort functions are located in a separate file
including a note which references the german wikipedia site.
Im not sure if i can use this code in a GPL software?
Best regards
Soeren
martinl
February 27, 2007, 4:05pm
2
2007/2/27, Sören Gebbert <soerengebbert@gmx.de>:
Dear devs,
The code:
I slightly tested the new r.univar/r3.univar module, no errors
occurred. From my point of view, the current r.univar code can be
replaced.
Martin
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
AFAICT you can, but the code itself is GFDL-licensed by the Wikipedia
article author. You could alternatively use GSL's heapsort which is
GPLed:
http://sourceware.org/cgi-bin/cvsweb.cgi/gsl/sort/sortvec.c?rev=1.5&content-type=text/x-cvsweb-markup&cvsroot=gsl
BTW I found that using code.google.com and searching for 'heapsort license:gpl'
Daniel.
-- Daniel Calvelo Aros
i had an eye on this code bevor,
but the wikipedia implementation was a bit nicer.
So i have chosen the wiki code.
But i recently found a gpl version of heapsort
and i think will use this one:
http://www.fh-augsburg.de/informatik/vorlesungen/c_cplus/tutorial/cyris/c-kurs16.htm
Best regards
Soeren
GPLed:
Daniel.
thanks for testing!
Because of the heapsort code issue, i have implemented a new version of r3/r.univar.
The heapsort code is now based on a GPL implementation which i have found in the net and it seems to work.
The original author of the heapsort code is noticed in the code.
The latest version is available here:
Best regards
Soeren
Martin Landa schrieb:
Dear devs,
The code:
replaced.
Martin
