re [r41158-60] d.vect: default line width to '1'
it is not correct. the default line width should be 0.
(at least in 6.x, I'm not sure about the display libs in 7)
see discussion in the ML archives if interested in why, or ping me later.
Hamish
Hamish
2010/2/22 Hamish <hamish_b@yahoo.com>:
(at least in 6.x, I'm not sure about the display libs in 7)see discussion in the ML archives if interested in why, or ping me later.
so why? testing all version, I cannot see difference between 0 and 1.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
2010/2/22 Martin Landa <landa.martin@gmail.com>:
anyway from user POV width=0 seems quite strange I guess.
Martin
> so why? testing all version, I cannot see difference between 0 and 1.anyway from user POV width=0 seems quite strange I guess.
XDRIVER passes the line width directly to XChangeGC. X specifies the
precise behaviour for non-zero line width, but drivers have some
freedom as to how zero-width lines are handled, so they can use the
hardware's "thin line" drawing primitive, if it has one. A width of
zero can potentially result in significantly faster operation.
2010/2/22 Glynn Clements <glynn@gclements.plus.com>:
OK, so should I revert the changes?
Martin
> zero can potentially result in significantly faster operation.OK, so should I revert the changes?
I think that the default line width should be zero, i.e. "thin" lines.
On drivers where there is no such thing as a "thin" line, the driver
will use a sensible default (which might not be the same as "1").
Glynn:
(done.)
2010/2/24 Hamish <hamish_b@yahoo.com>:
(done.)
and explained in the manual pages.
Martin
