> >Subject: d.out.png script copied to docs/html/ in err
> -for file in *.png *.jpg ; do \
> head -1 $$file | grep '#!/bin/sh' > /dev/null \
Also, I would just check for #! at the beginning of the line;
#!/bin/sh is too specific (e.g. you could have a space after the #!,
or it might be a script in some other language).
two points:
1) is it better to use `file $file | grep script` ?
Is "file" as portable as "head -1|cut -c1-2" will i18n break the grep?
2) are we going about it from the wrong end: the above doesn't copy the
file if it _is a script_. Shouldn't the test not copy the file if it
_isn't an image_?
> > >this bug's URL: http://intevation.de/rt/webrt?serial_num=4498
two points:
_isn't an image_?
If you are going to use "file", it would be better to check that the
file is an image, rather than not a script. But using "file" is more
problematic, as it isn't part of the coreutils package, and its output
depends upon the "magic" file (which might conceivably be localised).
To identify scripts, "^#!" is reliable, as that's what the kernel
checks for when it's asked to execute a file.
