Markus Neteler via RT wrote:
I have fixed some backslash formatting. Does it help?
No. Still:
ERROR: Cannot open toolbox:
Note: the problem affects v.digit in general, not only when -n (create
a new map) is used. Any v.digit run leads to the error above. I'm
changing the bug title.
If not, in doc/debugging.txt is a bit of tcl debugging explained. On
all my systems it works (tcl84). So I cannot reproduce the problem.
Maciek
