it is currently no more possible to compile the official
GRASS-GDAL-OGR plugin against GRASS 6.3-CVS. There is
a bug report open at GDAL:
http://trac.osgeo.org/gdal/ticket/1587
In summary, there a certain function definition needs
to be conditionalized upon the GRASS version but there
is the problem that it is defined as char in
include/version[.in].
Following question is open:
On Wed, Apr 25, 2007 at 03:58:03PM -0000, GDAL wrote:
#1587: Error compiling gdal-grass against gdal 1.4.1
Reporter: perrygeo | Owner: mloskot
Type: defect | Status: reopened
Priority: normal | Milestone:
Component: ConfigBuild | Version: 1.4.1
Severity: normal | Resolution:
Keywords: grass |
Comment (by mloskot):Markus,
Would it be possible to have version definition as a preprocessor macro
instead of character object?Ideally, I think it would be best if there is a version macro defined as a
number calculated as:{{{
MAJOR * 100000 + MINOR * 100 + MICRO
}}}what for '''6.3.0''' results as '''600300'''.
This way we have a value that can be easily calculated from version string
and makes it very easy to compare if one version is lower/higher from
another one.What do you think?
Ticket URL: <#1587 (Error compiling gdal-grass against gdal 1.4.1) – GDAL;
GDAL <http://trac.osgeo.org/gdal/>
Geospatial Data Abstraction Library is a translator library for raster and vector geospatial data formats.
Please suggest - the result should then be posted into the
GDAL bugtracker (you need to register for this, see trac).
