[GRASS-dev] Re: Gm::errmsg not defined in lib/gtcltk/gronsole.tcl
I took out this error reporting message box. It is not needed and clearly
causes occasional problems.
Michael
On 9/6/07 10:01 PM, "Markus Neteler" <neteler@itc.it> wrote:
Michael,
since I didn't see a change I guess so that it remains.
If you run a command (v.info somemap) and then, in the output
window click on the grey across (like rotated x) then
you should get the tcl error.
On Thu, Sep 06, 2007 at 09:59:01PM -0700, Michael Barton wrote:
Markus,
Is this still a problem? I don't source gm.tcl in gronsole.tcl because
gronsole.tcl is called by gm.tcl. So there should be no need to source
gm.tcl.
I'm running this now in x11 with no problem at all. Gm::errmsg is only being
called in 2 places, neither critical I think. If this is a general problem,
I can just take it out.
Michael
On 9/6/07 5:34 AM, "Markus Neteler" <neteler@itc.it> wrote:
Michael,
I am currently getting errors due to Gm::errmsg not defined in
(but used). Including
source $env(GISBASE)/etc/gm/gm.tcl
leads to an infinite loop... Maybe Gm::errmsg definition needs
to go into a different file?
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
