[GRASS-dev] Re: [GRASS-CVS] glynn: grass6/lib/init Makefile, 1.45, 1.46
grass@intevation.de wrote:
Author: glynn
Update of /grassrepository/grass6/lib/init
In directory doto:/tmp/cvs-serv30602/lib/init
Modified Files:
  Makefile
Log Message:
Only install .bat files on Windows
Glynn
On my Ubuntu, $GISBASE/etc/grass-run.bat and
$GISBASE/etc/Init.bat indeed don't get installed after your fix.
But $GISBASE/etc/nviz.bat and /usr/local/bin/grass63.bat
still do, only the latter is empty now.
Maciek
> Author: glynn
> Modified Files:
> Makefile
> Log Message:
Glynn
The fix only applies to lib/init; NVIZ wasn't touched.
grass63.bat doesn't get installed into dist.<arch>, but the top-level
Makefile still tries to process it:
  -sed -e "s#WINGISBASE=.*#WINGISBASE=${INST_DIR}#" ${ARCH_BINDIR}/grass${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}.bat > ${BINDIR}/grass${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}.bat
Try this:
--- Makefile 2 Oct 2007 17:46:31 -0000 1.132
+++ Makefile 16 Oct 2007 19:46:05 -0000
@@ -252,8 +252,10 @@
   test -d ${BINDIR} || ${MAKE_DIR_CMD} ${BINDIR}
   -sed -e "s#^GISBASE.*#GISBASE=${INST_DIR}#" ${ARCH_BINDIR}/grass${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR} > ${BINDIR}/grass${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}
   -chmod a+x ${BINDIR}/grass${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}
+ifneq ($(strip $(MINGW32)),)
   -chmod a+x ${BINDIR}/grass${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}.bat
+endif
   -cd ${GISBASE} ; tar cBf - bin | (cd ${INST_DIR} ; tar xBf - ) 2>/dev/null
   -cd ${GISBASE} ; tar cBf - bwidget | (cd ${INST_DIR} ; tar xBf - ) 2>/dev/null
   -cd ${GISBASE} ; tar cBf - docs | (cd ${INST_DIR} ; tar xBf - ) 2>/dev/null
Author: glynn
Modified Files:
  Makefile
Log Message:
Glynn
Try this:
+endif
Works for me. /usr/local/bin/grass63.bat don't get installed.
Maciek
