+However, you can find a list of standard GRASS <em>element</em> names in the
+file $GISBASE/etc/element_list. This is the file which g.remove/g.rename/g.copy
+use to determine which files need to be deleted/renamed/copied for a given
+entity type.
a style question: Up to now most GRASS documentation (HTML/MAN pages)
say "the user", here "you" was introduced.
Maybe it's a non-issue, but I feel that it the style of writing should
be decided and homogeneous.
+file $GISBASE/etc/element_list. This is the file which Hi,
Opinions?
Perhaps not a "big" issue, but not a non-issue either. It is largely a personal style choice. Using "one" is another option instead of "you", but that usage is falling out of style at least in North America. Personally I think the "the user" solution is a nice way around it, and that being consistent at least in man pages leads to a more polished product, and is therefore a good guideline. At the same time, I don't think that it's worth a major effort to scour all man/web pages to make it consistent, but (a) you weren't suggesting that, and (b) if someone wanted to, hey, it's open source
On the other hand, a more "personal" style might be appropriate in other, non-core materials, such as tutorials.
>> RCS file: /grassrepository/grass6/general/g.findfile/
>> description.html,v
>> names in the
> pages) say "the user", here "you" was introduced.
> should be decided and homogeneous.
> Opinions?
The inert-o-meter says:
$ cd grass63/dist.i686-pc-linux-gnu/docs/html
$ grep user * | wc -l
1230
$ grep you * | wc -l
280
$ grep one * | wc -l
621
"user" wins.
"one" is probably a bad test as it can refer to "figure one" etc. Also I
expect that might be more confusing for non-english users to translate.
In the same way, "you" might have multiple translation options that
english doesn't have (nous,vous; familiar,polite).. ? I guess it's not
too hard to figure out, but..
On Mon, 2006-10-23 at 21:28 +0200, Markus Neteler wrote:
On Mon, Oct 23, 2006 at 09:17:58PM +0200, grass@intevation.de wrote:
> RCS file: /grassrepository/grass6/general/g.findfile/description.html,v
> +entity type.
Opinions?
It is best to avoid referring to the user at all. Ex:
"...However, a list of standard GRASS <em>element</em> names can be
found in the file..."
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
