[GRASS-dev] Re: [GRASS-CVS] michael: grass6/lib/init epsg_option.tcl.in, 1.6, 1.7 file_option.tcl, 1.3, 1.4 gis_set.tcl, 1.33, 1.34
No. This is a mistake due to working on different machines.
Please put it back and I'll try again.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Reply-To: <grass-dev@grass.itc.it>
Date: Mon, 25 Sep 2006 13:18:57 -0500
To: Michael Barton <michael.barton@asu.edu>
Subject: Re: [GRASS-CVS] michael: grass6/lib/init epsg_option.tcl.in, 1.6, 1.7
You're reverting Windows patch. Is there any reason for that?
PROJSHARE for the browsedepsg variable shouldn't be replaced with any
other values (e.g., Mac OS X default) since lib/init/Makefile and
lib/init/projshare.sed will substitute the string with an appropriate
value.
Thank you.
Huidae
Author: michael
Update of /grassrepository/grass6/lib/init
In directory doto:/tmp/cvs-serv3750
Modified Files:
epsg_option.tcl.in file_option.tcl gis_set.tcl
Log Message:
change so that default widget format (including fonts) controled
by option database (in options.tcl)
Index: epsg_option.tcl.in
RCS file: /grassrepository/grass6/lib/init/epsg_option.tcl.in,v
retrieving revision 1.6
retrieving revision 1.7
diff -u -d -r1.6 -r1.7
--- epsg_option.tcl.in 15 Sep 2006 10:22:42 -0000 1.6
+++ epsg_option.tcl.in 25 Sep 2006 17:55:12 -0000 1.7
@@ -59,11 +59,10 @@
         global thelocation
         global browsedepsg
         global locpath
- global mingw
# NOTE: the epsg file is generated in GDAL for PROJ4
# with gdal/pymod/epsg_tr.py
- set browsedepsg "PROJSHARE/epsg"
+ set browsedepsg "/Library/Frameworks/PROJ.framework/Resources/proj/epsg"
         set epsgLocation "newLocation"
         set epsg_code ""
         set locpath $database
@@ -84,13 +83,13 @@
         #create the form and buttons
         label .optPopup.input1_ppb -text [G_msg "Name of new location"]
-justify right -height 2
- entry .optPopup.input1_ppbEntry -textvariable epsgLocation -width 35
-bg white
+ entry .optPopup.input1_ppbEntry -textvariable epsgLocation -width 35
         label .optPopup.input2_ppb -text [G_msg "Path to new location"]
- entry .optPopup.input2_ppbEntry -textvariable locpath -width 35 -bg
white
+ entry .optPopup.input2_ppbEntry -textvariable locpath -width 35
         label .optPopup.input3_ppb -text [G_msg "Path to the EPSG-codes
file"] -justify right -height 2
- entry .optPopup.input3_ppbEntry -textvariable browsedepsg -width 35
-bg white
+ entry .optPopup.input3_ppbEntry -textvariable browsedepsg -width 35
         label .optPopup.input4_ppb -text [G_msg "EPSG code number of
projection"] -justify right -height 2
- entry .optPopup.input4_ppbEntry -textvariable epsg_code -width 35
-bg white
+ entry .optPopup.input4_ppbEntry -textvariable epsg_code -width 35
#browse for database path
         button .optPopup.db -justify center -width 12 -text [G_msg
"Browse..."] \
@@ -108,7 +107,7 @@
         bind .optPopup.input3_ppbEntry <Leave> {
              if {$browsedepsg == ""} {
+ set browsedepsg
@@ -148,13 +147,8 @@
if {[file exists $browsedepsg]== 1} {
if {[file exists $thelocation ]==0} {
destroy .optPopup;
- if { $mingw == "1" } {
- exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e
$env(GISBASE)/etc/make_location_epsg.sh \
- $epsg_code $epsgLocation $locpath;
- } else {
- $epsg_code $epsgLocation $locpath >@stdout 2>@stderr;
+ exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e
+ $epsg_code $epsgLocation $locpath >@stdout 2>@stderr;
DialogGen .wrnDlg [G_msg "WARNING: restart GRASS please"] warning \
[G_msg "WARNING: Please restart GRASS in order find the created location in
the list (closing it for you now)"] \
0 OK;
@@ -301,7 +295,7 @@
         .infoPopup.text insert end [G_msg "\nThe folder (GRASS database) in
which the location should be created\n\n"] info
         .infoPopup.text insert end "\n"
         .infoPopup.text insert end [G_msg "\n EPSG code number of
projection:\n\n"] subtitle
- .infoPopup.text insert end [G_msg "\nEPSG code number of projection
(see PROJSHARE/epsg or push the 'EPSG-codes' button)\n\n"] info
+ .infoPopup.text insert end [G_msg "\nEPSG code number of projection
(see /Library/Frameworks/PROJ.framework/Resources/proj/epsg or push the
         pack .infoPopup.text -side left -fill both
Index: file_option.tcl
RCS file: /grassrepository/grass6/lib/init/file_option.tcl,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- file_option.tcl 14 Jun 2006 16:50:24 -0000 1.3
+++ file_option.tcl 25 Sep 2006 17:55:12 -0000 1.4
@@ -74,11 +74,11 @@
set loclab [label .fileloc.lab1 -text [G_msg "Name of new location"] -justify
right -height 2]
- set locname [entry .fileloc.loc -textvariable fileLocation -width 35 -bg
white]
+ set locname [entry .fileloc.loc -textvariable fileLocation -width 35]
set dblab [label .fileloc.lab2 -text [G_msg "Path to new location"] -justify
right -height 2]
- set dbpath [entry .fileloc.locpath -textvariable locpath -width 35 -bg
white]
+ set dbpath [entry .fileloc.locpath -textvariable locpath -width 35]
set filelab [label .fileloc.lab3 -text [G_msg "Path to georeferenced file"]
-justify right -height 2]
- set fpath [entry .fileloc.filepath -textvariable filepath -width 35 -bg
white]
+ set fpath [entry .fileloc.filepath -textvariable filepath -width 35]
set dbbrowse [button .fileloc.dbbrow -justify center -width 12 \
Index: gis_set.tcl
RCS file: /grassrepository/grass6/lib/init/gis_set.tcl,v
retrieving revision 1.33
retrieving revision 1.34
diff -u -d -r1.33 -r1.34
--- gis_set.tcl 16 Sep 2006 01:56:24 -0000 1.33
+++ gis_set.tcl 25 Sep 2006 17:55:12 -0000 1.34
@@ -19,12 +19,6 @@
-if {[info exists env(MSYSCON)]} {
- set mingw "1"
-} else {
- set mingw "0"
source $env(GISBASE)/etc/gtcltk/gmsg.tcl
@@ -32,6 +26,7 @@
# the EPSG codes (routines epsgLocCom and infoEpsg)
+source $env(GISBASE)/etc/gtcltk/options.tcl
source $env(GISBASE)/etc/epsg_option.tcl
source $env(GISBASE)/etc/file_option.tcl
@@ -284,22 +279,18 @@
proc gisSetWindow {} {
     global GRASSVERSION
- # Window manager configurations
- wm title . [format [G_msg "GRASS %s Startup"] $GRASSVERSION]
     global database
     global location
     global mymapset
     global mapset
     global oldDb oldLoc oldMap
     global env
     global grassrc_list
     global gisrc_name
- global mingw
+ # Window manager configurations
+ wm title . [format [G_msg "GRASS %s Startup"] $GRASSVERSION]
     # build .frame0
@@ -313,8 +304,10 @@
"$env(GISBASE)/etc/gintro.gif"]]
     set introtitle [text $titlefrm.msg -height 5 \
-relief flat -fg darkgreen \
- -font {Helvetica -14 bold} \
+ -bg #dddddd \
+ -font introfont \
-width 50 ]
     pack $titlefrm -side top
pack $introimg -side top
     pack $introtitle -side top
@@ -352,8 +345,7 @@
-relief {sunken} \
-textvariable database \
-width 40 \
- -xscrollcommand { .frame0.frameDB.mid.hscrollbar set} \
- -bg white
+ -xscrollcommand { .frame0.frameDB.mid.hscrollbar set}
     scrollbar .frame0.frameDB.mid.hscrollbar \
-command { .frame0.frameDB.mid.entry xview} \
@@ -361,31 +353,10 @@
-width 12 \
-orient {horizontal}
- # We cannot use Double-Button-1 (change dir) and Button-1 (select dir)
- # events at the same time because of MS-Windows TclTk's event bug.
- button .frame0.frameDB.right.button \
- -text [G_msg "Browse..."] \
- -command {set database [tk_chooseDirectory -initialdir $database \
- -parent .frame0 -title "New GIS data directory" -mustexist true]
- cd $database
- .frame0.frameLOC.listbox delete 0 end
- .frame0.frameMS.listbox delete 0 end
- foreach filename [lsort [glob -nocomplain *]] \
- if {[file isdirectory $filename]} \
- .frame0.frameLOC.listbox insert end $filename
- .frame0.frameBUTTONS.ok configure -state disabled}
- } else {
- -command {GetDir .frame0.frameDB.mid.entry .frame0.frameLOC.listbox \
- .frame0.frameMS.listbox}
+ button .frame0.frameDB.right.button \
+ -text [G_msg "Browse..."] \
+ -command {GetDir .frame0.frameDB.mid.entry .frame0.frameLOC.listbox \
+ .frame0.frameMS.listbox}
     pack .frame0.frameDB.left.label -side top
@@ -410,8 +381,7 @@
-relief {sunken} \
-exportselection false \
-yscrollcommand {.frame0.frameLOC.vscrollbar set} \
- -xscrollcommand {.frame0.frameLOC.hscrollbar set} \
- -bg white
+ -xscrollcommand {.frame0.frameLOC.hscrollbar set}
     scrollbar .frame0.frameLOC.vscrollbar -width 12 \
-command {.frame0.frameLOC.listbox yview} \
@@ -442,8 +412,7 @@
     listbox .frame0.frameMS.listbox \
-relief {sunken} \
-yscrollcommand {.frame0.frameMS.vscrollbar set} \
- -xscrollcommand {.frame0.frameMS.hscrollbar set} \
- -bg white
+ -xscrollcommand {.frame0.frameMS.hscrollbar set}
     scrollbar .frame0.frameMS.vscrollbar -width 12 \
-command {.frame0.frameMS.listbox yview} \
@@ -494,8 +463,7 @@
     entry .frame0.frameNMS.second.entry \
-relief {sunken} \
-textvariable mymapset \
- -width 22 \
- -bg white
+ -width 22
     button .frame0.frameNMS.third.button \
-text [G_msg "Create new mapset"] \
@@ -512,11 +480,11 @@
                 puts $varfp "DB_DRIVER: dbf"
                 puts $varfp "DB_DATABASE:
\$GISDBASE/\$LOCATION_NAME/\$MAPSET/dbf/"
                 close $varfp
- catch {file attributes $mymapset/VAR -permissions u+rw,go+r}
+ file attributes $mymapset/VAR -permissions u+rw,go+r
                 file mkdir $mymapset/dbf
                 #copy over the WIND definition:
- catch {file copy $mymapset/../PERMANENT/WIND $mymapset}
- catch {file attributes $mymapset/WIND -permissions u+rw,go+r}
+ file copy $mymapset/../PERMANENT/WIND $mymapset
+ file attributes $mymapset/WIND -permissions u+rw,go+r
                 .frame0.frameMS.listbox insert end $mymapset
                 #TODO: select new MAPSET
@@ -668,7 +636,7 @@
     cd $database
- foreach i [exec ls -a [pwd]] {
+ foreach i [exec ls -a [exec pwd]] {
if { [string compare $i "."] != 0 && \
             [string compare $i ".."] != 0 && \
             [file isdirectory $i] } {
@@ -694,7 +662,7 @@
     if { [file exists $location] } \
cd $location
[file isdirectory $i] && [file owned $i] } {
@@ -726,7 +694,7 @@
            %W insert 0 $new_path
            cd $new_path
@@ -734,7 +702,7 @@
- set database [pwd]
+ set database [exec pwd]
@@ -745,7 +713,7 @@
         set location [%W get [%W nearest %y]]
         cd $location
@@ -762,7 +730,7 @@
         cd $location
grass-commit mailing list
grass-commit@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass-commit
