[GRASS-dev] Re: grass-dev Digest, Vol 4, Issue 43
That would certainly make things easier from the GUI standpoint.
In a different vein, what about SVG instead of postscript for output from
d.* commands? Once in a GUI, both TclTk and wxPython can export their
graphic canvases to postscript easily.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Reply-To: <grass-dev@grass.itc.it>
Date: Sun, 13 Aug 2006 06:57:56 +0200
Subject: grass-dev Digest, Vol 4, Issue 43
I'm not entirely sure what you are proposing. The way that I would
approach it would be to make all of the fundamental GUI operations
(add/remove/show/hide layers, zoom/pan, etc) available as external
commands, so you would be able to do e.g. "g.ui add d.rast foo" to add
a new layer containing the output of "d.rast foo".
It would be fairly straightforward to modify the raster library so
that executing a d.* command would send a command to the GUI to add
that command as a new layer.
d.* commands?
The same issues would apply, although I would expect SVG rendering to
be faster, as it was designed primarily for video display rather than
hardcopy.
wxPython has a retained-mode canvas? Or is that feature based upon
using Xprint (or similar)?
I don't know yet.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Sun, 13 Aug 2006 09:54:25 +0100
To: Michael Barton <michael.barton@asu.edu>
Cc: <grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] Re: grass-dev Digest, Vol 4, Issue 43
